Scotts8471
- Mar 9, 2014
I have a 2012 Apex XTX, will the torsion springs (2200nm) from a Venture work?
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
are you trying to go softer of harder? Travis at Barn of parts you can find him on here or google barn of parts he is a used parts vendor on this site and will know your answer for sure and will most likely have anything you may be looking for too great guy!!
Scotts8471
- Mar 9, 2014
I want to go stiffer. Put a seat jack on for the wife. Only time I ride it, it will be 2 up.are you trying to go softer of harder? Travis at Barn of parts you can find him on here or google barn of parts he is a used parts vendor on this site and will know your answer for sure and will most likely have anything you may be looking for too great guy!!
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
I did the same thing I recoded you do the stiffer springs and the 4 poss adjusters. Travis can hook you up for sure.
Scotts8471
- Mar 9, 2014
Did you use venture springs?I did the same thing I recoded you do the stiffer springs and the 4 poss adjusters. Travis can hook you up for sure.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
I used what Travis sent me
Sent from my XT1564 using Tapatalk
Scotts8471
- Mar 9, 2014
OK thank you. Appreciate the help.I used what Travis sent me
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
if you give him a call he will tell you your answer he is a great guy even if you are not going to buy from him he will still answer the question he also makes 4 poss adjusters . my opinion they are great as some times its the wife and some times its the little guy on the back and for me lots of times I am solo on it.
Scotts8471
- Mar 9, 2014
I talked to Travis and he told me what set up you're using. Just Curious to what your weight is and if you bottom out much when riding double? Thanks again for your help.if you give him a call he will tell you your answer he is a great guy even if you are not going to buy from him he will still answer the question he also makes 4 poss adjusters . my opinion they are great as some times its the wife and some times its the little guy on the back and for me lots of times I am solo on it.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
I weigh 260 without gear. with my son on back springs full max we will almost never bottom out with wife on back about 150 lbs no gear the hard bumps will find the bottom.
Scotts8471
- Mar 9, 2014
OK awesome I'm 240 and the wife is 110 so I should be fine. Thanks again.I weigh 260 without gear. with my son on back springs full max we will almost never bottom out with wife on back about 150 lbs no gear the hard bumps will find the bottom.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
No prob
