sledfreak440
- Dec 1, 2014
hi, I recently had no spark in my ignition system so then I had changed my ignition coil and my bike started up. I didn't even drive 1 km and parked it, then around hunting season I go to start it, it ran then suddenly stopped like 5 seconds after and didn't want to start back up again. I'm not sure if its the kill switch that's doesn't allow spark or if its another issue? possibly my coil again? Anyways, any help is greatly appreciated.
the handlebar switches need to be taken apart and cleaned periodically. good idea to go through and clean all the ground points on the bike as well to start with.
sledfreak440
- Dec 1, 2014
Thank you ill start with that and see.
sledfreak440
- Dec 1, 2014
Still nothing, and I have to keep my battery on charge or else it doesnt even turn over or the green light on, its like Id have no power
battery testing good? that bike should run without a battery though.
any progress?
