jake7662
- Feb 26, 2017
- New hamshire
- 09 Yamaha nytro xtx
I have a 2009 Yamaha nytro xtx. I'm having issues with it pulling to the left when I'm coming to a stop. Just rebuilt the entire front end new ball joints outter tie rod ends, and all new a-arm bushings. I do have play in my ski bushings that is about the only think I didn't replace. Could that be causing my issue? I feel like I am constantly pull the handle bars to the right while riding. I did do a ski alignment after all the work was done and it is toed out about 1/8 to 1/4. Any advice would be great
Gone Blue
- Oct 11, 2006
- Howell, Michigan
Hmm, it would seem that if you have play in the ski spindle bushings your toe adjustment might not be accurate? G.B.
jake7662
- Feb 26, 2017
- New hamshire
That's what I'm thinking and my left ski bushing is worse then my right ski bushing. I messaged up bushman to order a set of his ski bushing. Waiting for a response.Hmm, it would seem that if you have play in the ski spindle bushings your toe adjustment might not be accurate? G.B.
Gone Blue
- Oct 11, 2006
- Howell, Michigan
Yeah, I think I would start there and see how that goes. I received one of UPbushman's spindle kits a couple weeks ago for an 08' RTX I recently picked up. I used one of these kits on my Phazer and it is a sweet set up. G.B.That's what I'm thinking and my left ski bushing is worse then my right ski bushing. I messaged up bushman to order a set of his ski bushing. Waiting for a response.
herndonp
Upbushman is the way to go. I would also go 1/4-3/8 toe out. I have mine at 1/2- 5/8, but I'm running curve skis and found that toe out to be better.
Pete
Pete
tnc110
- Jan 5, 2015
- Sidewinder BTX SE, SRXs
Make sure your carbides are in good shape. I had a sled the carbide got hung up and bent real bad sled would pull really hard to one side
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
I agree with "check carbides" as I have twice seen bent carbides lead to a constant pull to the side. Once on Apex other a Poo. Not that it matters.
I have the same thread on this issue to a T. Long story short I did a-arm bushings upbushmans kit and alignment and tow adjustment. Nothing fixed it. Turns out the left carbide was chipped in the front so it was at a 90 degree angle to the snow. Didn't look bad at all but I changed them and it drove and stopped straight as an arrow. Good luck, let us know what you find.
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
If you're running the stock skis or skis that aren't left/right specific I'd swap them to see if the direction changes with the skis. A bent frame can also cause a pulling issue due to misalignment.
jake7662
- Feb 26, 2017
- New hamshire
I checked my carbids. They looked fine don't notic any real issues. I'm running the Yamaha tuner skis. I adjusted my track it was mis aligned a very small amount. Went for a 130 mile ride today nothing changed still waiting for the new front ski bushing set in the mail. How would I know if the frame is bent? I know my front a frame got tweaked due to the front lower plate has 2 places it's bent up. Im going to put the new bushings in and realign the skis again I will see if anything changes.
jake7662
- Feb 26, 2017
- New hamshire
I think this is my problem bent carbid. On the left ski which is the way it is pulling.
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
That's one warped 2x4!
jake7662
- Feb 26, 2017
- New hamshire
Anyone know the correct part # for a 4" or 2" Yamaha tuner ski carbide can't really seem to find it
porkchop
