Yamaha YXZ1000R Secret Suspension Settings
FRONT |
High Speed Compression: 3.5 clicks out
Low Speed Compression: 3.5 clicks out
Rebound: 20 clicks out
REAR |
Rebound: 15 clicks out
Direct link
FRONT |
REAR |
Direct link
Joshua
- Apr 14, 2010
- Newfoundland
- 2018 Yamaha Sidewinder BTX LE 50TH
I don't believe this will work. I been playing with the suspension since new. Can't seem to make it soft enough.
I have tried them but not sure if they are any better then stock. What was your best set up?
Joshua
- Apr 14, 2010
- Newfoundland
High and low speed all the way out. Rebound in the rear out but in the front rebound all the way in. Take a look at YXZ talk forum, alot of information regarding the sxs. But not as good as this site. Not ever close
I will have to take a look out there. Hard to go someplace else . How did you like the ride with the adjustments you made?
edunn69
- Aug 4, 2004
- Oswego, Il
- 99 & 01 SRX, 01 SX-R, 99 Phazer, 07 Attak, 14 Viper LTX SE(sold), YXZ1000R
You'll have to replace the springs to get it set up right, it's way oversprung in the rear.
I heard this was the trick for that:
https://www.schmidtyracing.com/product-p/ut-spk-dr-yzx-rst.htm
edunn69
- Aug 4, 2004
- Oswego, Il
The tenders definitely help and make a big difference. I ended up pulling those off too and am now running a set of Eibach springs which made a huge difference.I heard this was the trick for that:
You have a link to them?
edunn69
- Aug 4, 2004
- Oswego, Il
These are the ones I'm running now.You have a link to them?
https://www.sxsperformance.com/eiba...gle_shopping&gclid=CNzypaqNps4CFYGBaQodX6AJBw
If you want to stay on a lower budget, the tenders from Schmidty will definitely help, but that was kind of the early version of a fix.
Holy crap that pricey for some springs.
- 32K
- 146K
