I want to install a ZEX tps switch to a Holtzman NO2 kit. Where does the switch fit in to the existing install?
87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
Search my post on the Holtzman, I use the ZEX switch.
87gtNOS
- Nov 30, 2005
- Toronto
87gtNOS said:Search my post on the Holtzman, I use the ZEX switch.
oh and I see you have a nytro...the TPS wires are likely basically the same....
Your post is what got me to this point but I don't see any post that actually points out the location of the TPS wire. I think I have figured it out though its just in a spot that will require me to remove the fuel tank to make it easier to access. What did you use to splice the TPS wire? Scotch block?
87gtNOS
- Nov 30, 2005
- Toronto
nytrozula said:Your post is what got me to this point but I don't see any post that actually points out the location of the TPS wire. I think I have figured it out though its just in a spot that will require me to remove the fuel tank to make it easier to access. What did you use to splice the TPS wire? Scotch block?
I believe I actually snipped and soldered mine...
