Broken bolt
upei93
Dalhousie, NB
Canada
2015 Viper X-TX LE MPI turbo
2009 Nytro XTX
You can add me to the broken bolt club. Quick question, do the 09 XTX's have this o-ring??
radianguy said:
I'm pretty sure mine did.
Thats funny because I can't find it...I'll have to order one.
I'm trying to remember which piece that oring goes on.. One of the gears? Whatever it is, it has a chamfered edge that the oring seats in...
When I had mine apart, that little oring stuck to something, and I only noticed it at the last moment.. And got it back in place.
It looks so new! Lol until it's taken apart a couple times. My little spring that goes between the reverse gears got destroyed. Is this an important piece or can I run without it? I don't have that o-ring either..
That o-ring goes on before you slide on the collar that seals the top of the chain case. My 09 XTX does have that. If you put the chaincase back together without that o-ring installed, a small amount oil will seep out on the top shaft.
Page 4-17 in Nytro FAQ 08 service manual. I would think they would be same.
Doesn't have an actual number for the o-ring but, shows where it goes.
What he said. ^
Found the o-ring now how do I get the other half of the bolt out...drill it and an easy out or is there an easier way??
Dimebag said:
The easy way is to leave it there, and run without the bolt.
Wouldn't be able to sleep at night...lol
Been running without for 2000 miles, I sleep much better knowing the broken bolt is not trying to eat its way through the cover.
I used a drill and an easy out. Came out nicely. Just take your time with it, and it'll go smoothly.
