beeze455
- Nov 23, 2010
- Bowdoinham, ME
- www.gopherdesign.com
So last year, I came up with a real easy way to get rid of the yamaha brake setup. I hated the Yamaha parking brake setup from day 1 and it also included extra weight. If it was the same weight, I would most likely still do this mod. Did not take detailed pictures while I did this, but pieced together some others.
Buy an Arctic Cat brake with hydraulic cyl. I know the one from a ZR works, but I am sure many many others work. I actually bet one that had a rubber hose already going to it would work better and have the banjo bolt already. I only paid 10 dollars for the hole setup and see them on ebay all over the place for 50. Tons of these old cats exist.
Now that you have the brake in your hand. You will need everything except the circled pieces.
Now take off the Yamaha brake assembly. The item circled in red will need to be cut off with a dremel or something.
You either need to trim the Yamaha banjo bolt to fit the cat cyl or find the correct one. perhaps an arctic cat one or one from an auto store. The Yamaha one cut with a dremel has worked fine for me.
The cat side and yamaha side will now bolt right together.
Part Number: 0602-943
Brake Assembly (inc. 2-14)
Replaces 0602-831
1998 POWDER SPECIAL 600 - HYDRAULIC BRAKE CONTROL ASSEMBLY
1998 EXT 600 TOUR - HYDRAULIC BRAKE CONTROL ASSEMBLY
1998 COUGAR MOUNTAIN CAT - HYDRAULIC BRAKE CONTROL ASSEMBLY
1998 ZR 440 - HYDRAULIC BRAKE CONTROL ASSEMBLY
1998 ZRT 600 - HYDRAULIC BRAKE CONTROL ASSEMBLY
1998 ZR 600 EFI LE XC - HYDRAULIC BRAKE CONTROL ASSEMBLY
1998 ZL 440 - HYDRAULIC BRAKE CONTROL ASSEMBLY
1998 THUNDERCAT - HYDRAULIC BRAKE CONTROL ASSEMBLY
1998 POWDER SPECIAL 600 EFI LE - HYDRAULIC BRAKE CONTROL ASSEMBLY
1998 ZR 600 EFI LE - HYDRAULIC BRAKE CONTROL ASSEMBLY
1998 POWDER EXTREME - HYDRAULIC BRAKE CONTROL ASSEMBLY
1998 EXT 580 EFI - HYDRAULIC BRAKE CONTROL ASSEMBLY
1998 COUGAR DELUXE - HYDRAULIC BRAKE CONTROL ASSEMBLY
1998 ZR 600 - HYDRAULIC BRAKE CONTROL ASSEMBLY
1998 ZR 440 SNO-PRO - HYDRAULIC BRAKE CONTROL ASSEMBLY
1998 ZR 600 EFI - HYDRAULIC BRAKE CONTROL ASSEMBLY
1998 Z 440 - HYDRAULIC BRAKE CONTROL ASSEMBLY
1998 PANTERA 800 - HYDRAULIC BRAKE CONTROL ASSEMBLY
1998 POWDER SPECIAL 600 EFI - HYDRAULIC BRAKE CONTROL ASSEMBLY
1998 EXT EFI DLX - HYDRAULIC BRAKE CONTROL ASSEMBLY
1998 EXT 580 EFI DLX - HYDRAULIC BRAKE CONTROL ASSEMBLY
1998 EXT 600 TRIPLE - HYDRAULIC BRAKE CONTROL ASSEMBLY
1998 ZR 500 - HYDRAULIC BRAKE CONTROL ASSEMBLY
1998 COUGAR - HYDRAULIC BRAKE CONTROL ASSEMBLY
1998 ZRT 800 - HYDRAULIC BRAKE CONTROL ASSEMBLY
1998 ZR 500 - BRAKE CONTROL ASSEMBLY
1998 ZL 500 - HYDRAULIC BRAKE CONTROL ASSEMBLY
1998 THUNDERCAT MC - HYDRAULIC BRAKE CONTROL ASSEMBLY
1998 PANTERA 580 - HYDRAULIC BRAKE CONTROL ASSEMBLY
1999 PANTERA 580 EFI - HYDRAULIC BRAKE CONTROL ASSEMBLY
1999 Z 440 SNO-PRO - HYDRAULIC BRAKE CONTROL ASSEMBLY
1999 POWDER SPECIAL 600 EFI II LE - HYDRAULIC BRAKE CONTROL ASSEMBLY
1999 PANTHER 550 - HYDRAULIC BRAKE CONTROL ASSEMBLY
1999 ZRT 800 - HYDRAULIC BRAKE CONTROL ASSEMBLY
1999 Z 440 - HYDRAULIC BRAKE CONTROL ASSEMBLY
1999 ZL 500 EFI - HYDRAULIC BRAKE CONTROL ASSEMBLY
1999 ZR 600 LE - HYDRAULIC BRAKE CONTROL ASSEMBLY
1999 ZR 600 - HYDRAULIC BRAKE CONTROL ASSEMBLY
1999 ZL 440 - HYDRAULIC BRAKE CONTROL ASSEMBLY
1999 ZR 500 LE - HYDRAULIC BRAKE CONTROL ASSEMBLY
1999 THUNDERCAT - HYDRAULIC BRAKE CONTROL ASSEMBLY
1999 POWDER SPECIAL 700 LE - HYDRAULIC BRAKE CONTROL ASSEMBLY
1999 POWDER SPECIAL 600 EFI I - HYDRAULIC BRAKE CONTROL ASSEMBLY
1999 TRIPLE TOURING - HYDRAULIC BRAKE CONTROL ASSEMBLY
1999 ZR 440 SNO-PRO - HYDRAULIC BRAKE CONTROL ASSEMBLY
1999 ZL 600 EFI S/N 9915688 AND UP - HYDRAULIC BRAKE CONTROL ASSEMBLY
1999 ZL 500 - HYDRAULIC BRAKE CONTROL ASSEMBLY
1999 ZR 600 EFI LE - HYDRAULIC BRAKE CONTROL ASSEMBLY
1999 ZR 500 EFI LE - HYDRAULIC BRAKE CONTROL ASSEMBLY
1999 POWDER SPECIAL 500 EFI - HYDRAULIC BRAKE CONTROL ASSEMBLY
1999 ZR 500 - HYDRAULIC BRAKE CONTROL ASSEMBLY
1999 PANTERA 800 - HYDRAULIC BRAKE CONTROL ASSEMBLY
1999 POWDER SPECIAL 700 - HYDRAULIC BRAKE CONTROL ASSEMBLY
1999 POWDER SPECIAL 600 - HYDRAULIC BRAKE CONTROL ASSEMBLY
1999 ZRT 600 - HYDRAULIC BRAKE CONTROL ASSEMBLY
1999 ZL 600 EFI S/N < 9915688 - HYDRAULIC BRAKE CONTROL ASSEMBLY
1999 ZL 600 - HYDRAULIC BRAKE CONTROL ASSEMBLY
1999 ZR 700 - HYDRAULIC BRAKE CONTROL ASSEMBLY
1999 ZR 600 EFI - HYDRAULIC BRAKE CONTROL ASSEMBLY
1999 ZR 500 EFI - HYDRAULIC BRAKE CONTROL ASSEMBLY
1999 THUNDERCAT MC - HYDRAULIC BRAKE CONTROL ASSEMBLY
2000 THUNDERCAT THC - HYDRAULIC BRAKE CONTROL ASSEMBLY
2000 THUNDER - HYDRAULIC BRAKE CONTROL ASSEMBLY
2000 Z 440 SNO PRO - HYDRAULIC BRAKE CONTROL ASSEMBLY
2000 POWDER SPECIAL 700 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2000 POWDER SPECIAL 600 EFI - HYDRAULIC BRAKE CONTROL ASSEMBLY
2000 POWDER SPECIAL 500 EFI - HYDRAULIC BRAKE CONTROL ASSEMBLY
2000 POWDER SPECIAL 2K - HYDRAULIC BRAKE CONTROL ASSEMBLY
2000 ZR 700 - LE - HYDRAULIC BRAKE CONTROL ASSEMBLY
2000 ZR 600 EFI - LE REVERSE - HYDRAULIC BRAKE CONTROL ASSEMBLY
2000 ZR 600 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2000 ZL 700 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2000 ZL 600 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2000 ZL 500 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2000 BEARCAT WIDE TRACK - HYDRAULIC BRAKE CONTROL ASSEMBLY
2000 THUNDERCAT MC - HYDRAULIC BRAKE CONTROL ASSEMBLY
2000 PANTERA 1000 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2000 POWDER SPECIAL 600 LE - HYDRAULIC BRAKE CONTROL ASSEMBLY
2000 POWDER SPECIAL 600 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2000 PANTERA 580 EFI - HYDRAULIC BRAKE CONTROL ASSEMBLY
2000 PANTHER 550 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2000 ZRT 800 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2000 ZR 700 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2000 ZR 600 EFI - LE - HYDRAULIC BRAKE CONTROL ASSEMBLY
2000 ZR 500 EFI - HYDRAULIC BRAKE CONTROL ASSEMBLY
2000 ZL 580 EFI ESR - HYDRAULIC BRAKE CONTROL ASSEMBLY
2000 ZL 550 ESR - HYDRAULIC BRAKE CONTROL ASSEMBLY
2000 TRIPLE TOURING 600 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2000 THUNDERCAT - HYDRAULIC BRAKE CONTROL ASSEMBLY
2000 ZR 440 SNO PRO - HYDRAULIC BRAKE CONTROL ASSEMBLY
2000 POWDER SPECIAL 700 LE - HYDRAULIC BRAKE CONTROL ASSEMBLY
2000 POWDER SPECIAL 600 EFI LE - HYDRAULIC BRAKE CONTROL ASSEMBLY
2000 POWDER SPECIAL 500 EFI LE - HYDRAULIC BRAKE CONTROL ASSEMBLY
2000 ZR 2K - HYDRAULIC BRAKE CONTROL ASSEMBLY
2000 ZRT 600 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2000 ZR 600 BLAIR MORGAN SIGNATURE EDITION - HYDRAULIC BRAKE CONTROL ASSEMBLY
2000 ZR 600 EFI - HYDRAULIC BRAKE CONTROL ASSEMBLY
2000 ZR 500 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2000 ZL 440 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2000 ZL 600 EFI - HYDRAULIC BRAKE CONTROL ASSEMBLY
2000 ZL 500 EFI - HYDRAULIC BRAKE CONTROL ASSEMBLY
2001 BEARCAT WIDE TRACK - HYDRAULIC BRAKE CONTROL ASSEMBLY
2001 MOUNTAIN CAT 600 EFI - HYDRAULIC BRAKE CONTROL ASSEMBLY
2001 PANTERA 580 EFI - HYDRAULIC BRAKE CONTROL ASSEMBLY
2001 ZR 600 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2001 THUNDERCAT - HYDRAULIC BRAKE CONTROL ASSEMBLY
2001 Z 440 SNO PRO - HYDRAULIC BRAKE CONTROL ASSEMBLY
2001 ZL 550 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2001 PANTHER 550 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2001 ZR 800 LE - HYDRAULIC BRAKE CONTROL ASSEMBLY
2001 MOUNTAIN CAT 800 LE - HYDRAULIC BRAKE CONTROL ASSEMBLY
2001 ZRT 600 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2001 ZR 600 EFI - HYDRAULIC BRAKE CONTROL ASSEMBLY
2001 PANTERA 1000 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2001 MOUNTAIN CAT 1000 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2001 ZRT 800 LE - HYDRAULIC BRAKE CONTROL ASSEMBLY
2001 MOUNTAIN CAT 600 VEV - HYDRAULIC BRAKE CONTROL ASSEMBLY
2001 ZR 500 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2001 ZR 800 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2001 MOUNTAIN CAT 800 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2001 ZL 600 EFI - HYDRAULIC BRAKE CONTROL ASSEMBLY
2001 MOUNTAIN CAT 600 EFI LE - HYDRAULIC BRAKE CONTROL ASSEMBLY
2001 MOUNTAIN CAT 500 EFI - HYDRAULIC BRAKE CONTROL ASSEMBLY
2001 ZR 500 EFI - HYDRAULIC BRAKE CONTROL ASSEMBLY
2001 ZRT 800 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2001 ZR 440 SNO PRO - HYDRAULIC BRAKE CONTROL ASSEMBLY
2001 ZL 500 EFI ESR - HYDRAULIC BRAKE CONTROL ASSEMBLY
2001 ZR 600 VEV - HYDRAULIC BRAKE CONTROL ASSEMBLY
2001 TRIPLE TOURING 600 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2001 ZL 800 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2001 ZRT 600 LE - HYDRAULIC BRAKE CONTROL ASSEMBLY
2001 ZR 600 EFI LE - HYDRAULIC BRAKE CONTROL ASSEMBLY
2002 ZL 800 EFI ESR - HYDRAULIC BRAKE CONTROL ASSEMBLY
2002 Z 440 SNO PRO - HYDRAULIC BRAKE CONTROL ASSEMBLY
2002 ZL 600 EFI SS - HYDRAULIC BRAKE CONTROL ASSEMBLY
2002 MOUNTAIN CAT 600 EFI - HYDRAULIC BRAKE CONTROL ASSEMBLY
2002 ZL 500 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2002 PANTERA 600 EFI ESR - HYDRAULIC BRAKE CONTROL ASSEMBLY
2002 ZR 800 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2002 ZR 600 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2002 ZR 500 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2002 Z 570 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2002 MOUNTAIN CAT 500 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2002 ZRT 600 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2002 4-STROKE TRAIL - HYDRAULIC BRAKE CONTROL ASSEMBLY
2002 MOUNTAIN CAT 1000 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2002 MOUNTAIN CAT 800 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2002 ZL 600 EFI - HYDRAULIC BRAKE CONTROL ASSEMBLY
2002 MOUNTAIN CAT 570 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2002 THUNDERCAT - HYDRAULIC BRAKE CONTROL ASSEMBLY
2002 PANTERA 550 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2002 ZR 800 EFI CC - HYDRAULIC BRAKE CONTROL ASSEMBLY
2002 ZR 600 EFI - HYDRAULIC BRAKE CONTROL ASSEMBLY
2002 ZR 500 LE - HYDRAULIC BRAKE CONTROL ASSEMBLY
2002 PANTHER 570 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2002 BEARCAT WIDE TRACK - HYDRAULIC BRAKE CONTROL ASSEMBLY
2002 ZL 800 EFI SS - HYDRAULIC BRAKE CONTROL ASSEMBLY
2002 4-STROKE TOURING - HYDRAULIC BRAKE CONTROL ASSEMBLY
2002 MOUNTAIN CAT 800 EFI - HYDRAULIC BRAKE CONTROL ASSEMBLY
2002 ZL 550 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2002 PANTERA 800 EFI ESR - HYDRAULIC BRAKE CONTROL ASSEMBLY
2002 ZR 800 EFI - HYDRAULIC BRAKE CONTROL ASSEMBLY
2002 ZR 800 CC - HYDRAULIC BRAKE CONTROL ASSEMBLY
2002 ZR 600 EFI CC - HYDRAULIC BRAKE CONTROL ASSEMBLY
2002 ZR 500 CC - HYDRAULIC BRAKE CONTROL ASSEMBLY
2002 Z 570 SS - HYDRAULIC BRAKE CONTROL ASSEMBLY
2003 PANTERA 600 EFI ESR - HYDRAULIC BRAKE CONTROL ASSEMBLY
2003 MOUNTAIN CAT 900 EARLY BUILD - HYDRAULIC BRAKE CONTROL ASSEMBLY
2003 BEARCAT WIDE TRACK - HYDRAULIC BRAKE CONTROL ASSEMBLY
2003 PANTHER 570 ESR - HYDRAULIC BRAKE CONTROL ASSEMBLY
2003 PANTERA 800 EFI ESR - HYDRAULIC BRAKE CONTROL ASSEMBLY
2003 MOUNTAIN CAT 570 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2003 ZR 900 EARLY BUILD - HYDRAULIC BRAKE CONTROL ASSEMBLY
2003 440 SNO PRO L/C - HYDRAULIC BRAKE CONTROL ASSEMBLY
2003 MOUNTAIN CAT 800 EFI - HYDRAULIC BRAKE CONTROL ASSEMBLY
2003 Z 570 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2003 PANTERA 550 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2003 MOUNTAIN CAT 900 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2003 MOUNTAIN CAT 900 1M - HYDRAULIC BRAKE CONTROL ASSEMBLY
2003 MOUNTAIN CAT 600 EFI - HYDRAULIC BRAKE CONTROL ASSEMBLY
2003 4-STROKE TOURING - HYDRAULIC BRAKE CONTROL ASSEMBLY
2003 4-STROKE TRAIL - HYDRAULIC BRAKE CONTROL ASSEMBLY
2004 PANTERA 600 EFI - HYDRAULIC BRAKE CONTROL ASSEMBLY
2004 PANTHER 570 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2004 KING CAT 900 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2004 MOUNTAIN CAT 900 159 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2004 MOUNTAIN CAT 800 EFI 151 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2004 T660 TURBO TRAIL - HYDRAULIC BRAKE CONTROL ASSEMBLY
2004 T660 TURBO TOURING - HYDRAULIC BRAKE CONTROL ASSEMBLY
2004 Z 570 LX - HYDRAULIC BRAKE CONTROL ASSEMBLY
2004 PANTERA 550 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2004 MOUNTAIN CAT 900 EFI 159 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2004 MOUNTAIN CAT 900 151 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2004 MOUNTAIN CAT 600 EFI - HYDRAULIC BRAKE CONTROL ASSEMBLY
2004 BEARCAT 570 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2004 PANTERA 800 EFI - HYDRAULIC BRAKE CONTROL ASSEMBLY
2004 Z 570 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2004 BEARCAT WIDE TRACK - HYDRAULIC BRAKE CONTROL ASSEMBLY
2004 MOUNTAIN CAT 900 EFI 151 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2004 ARCTIC CAT 440 SNO PRO - HYDRAULIC BRAKE CONTROL ASSEMBLY
2004 MOUNTAIN CAT 800 EFI 159 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2004 T660 TOURING - HYDRAULIC BRAKE CONTROL ASSEMBLY
2004 MOUNTAIN CAT 570 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2005 BEARCAT 570 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2005 AC SNO PRO MOD - HYDRAULIC BRAKE CONTROL ASSEMBLY
2005 T660 TURBO - HYDRAULIC BRAKE CONTROL ASSEMBLY
2005 PANTERA 600 EFI - HYDRAULIC BRAKE CONTROL ASSEMBLY
2005 Z 570 LX - HYDRAULIC BRAKE CONTROL ASSEMBLY
2005 KING CAT 900 EFI - HYDRAULIC BRAKE CONTROL ASSEMBLY
2005 BEARCAT WIDE TRACK - HYDRAULIC BRAKE CONTROL ASSEMBLY
2005 AC 440 SNO PRO - HYDRAULIC BRAKE CONTROL ASSEMBLY
2005 T660 TURBO TOURING - HYDRAULIC BRAKE CONTROL ASSEMBLY
2005 PANTERA 550 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2005 T660 TURBO ST - HYDRAULIC BRAKE CONTROL ASSEMBLY
2005 Z 570 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2005 KING CAT 900 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2005 KING CAT 900 EFI EARLY BUILD - HYDRAULIC BRAKE CONTROL ASSEMBLY
2005 T660 TOURING - HYDRAULIC BRAKE CONTROL ASSEMBLY
2005 PANTHER 570 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2005 T660 TURBO ST EFI EARLY BUILD - HYDRAULIC BRAKE CONTROL ASSEMBLY
2006 PANTHER 570 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2006 KING CAT 900 EFI - HYDRAULIC BRAKE CONTROL ASSEMBLY
2006 BEARCAT 570 LONG TRACK - HYDRAULIC BRAKE CONTROL ASSEMBLY
2006 PANTHER 660 TRAIL - HYDRAULIC BRAKE CONTROL ASSEMBLY
2006 Z 570 LX - HYDRAULIC BRAKE CONTROL ASSEMBLY
2006 PANTHER 660 TOURING - HYDRAULIC BRAKE CONTROL ASSEMBLY
2006 Z 570 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2007 Z 570 - HYDRAULIC BRAKE CONTROL ASSEMBLY
2007 BEARCAT 570 LONG TRACK - HYDRAULIC BRAKE CONTROL ASSEMBLY
2007 Z 570 LX - HYDRAULIC BRAKE CONTROL ASSEMBLY
2008 BEARCAT 570 LONG TRACK - HYDRAULIC BRAKE CONTROL ASSEMBLY
2008 BEARCAT 570 LONG TRACK - HYDRAULIC BRAKE CONTROL ASSEMBLY (CANADIAN)
Part Number: 0602-831
Replaced by 0602-943
1996 EXT POWDER SPECIAL - HYDRAULIC BRAKE CONTROL ASSEMBLY
1996 EXT EFI - HYDRAULIC BRAKE CONTROL ASSEMBLY
1996 ZRT 600 - HYDRAULIC BRAKE CONTROL ASSEMBLY
1996 ZR 440 - HYDRAULIC BRAKE CONTROL ASSEMBLY
1996 WILDCAT MOUNTAIN CAT - HYDRAULIC BRAKE CONTROL ASSEMBLY
1996 THUNDERCAT - HYDRAULIC BRAKE CONTROL ASSEMBLY
1996 EXT 580 EFI DX - HYDRAULIC BRAKE CONTROL ASSEMBLY
1996 EXT 580 - HYDRAULIC BRAKE CONTROL ASSEMBLY
1996 ZR 580 EFI ETT - HYDRAULIC BRAKE CONTROL ASSEMBLY
1996 ZR 580 - HYDRAULIC BRAKE CONTROL ASSEMBLY
1996 Z 440 - HYDRAULIC BRAKE CONTROL ASSEMBLY
1996 WILDCAT - HYDRAULIC BRAKE CONTROL ASSEMBLY
1996 PANTERA - HYDRAULIC BRAKE CONTROL ASSEMBLY
1996 EXT EFI MOUNTAIN CAT - HYDRAULIC BRAKE CONTROL ASSEMBLY
1996 ZRT 800 - HYDRAULIC BRAKE CONTROL ASSEMBLY
1996 ZR 580 EFI - HYDRAULIC BRAKE CONTROL ASSEMBLY
1996 WILDCAT TOURING - HYDRAULIC BRAKE CONTROL ASSEMBLY
1996 THUNDERCAT MOUNTAIN - HYDRAULIC BRAKE CONTROL ASSEMBLY
1997 ZR 580 EFI - HYDRAULIC BRAKE CONTROL ASSEMBLY
1997 Z 440 - HYDRAULIC BRAKE CONTROL ASSEMBLY
1997 PANTERA - HYDRAULIC BRAKE CONTROL ASSEMBLY
1997 POWDER EXTREME - HYDRAULIC BRAKE CONTROL ASSEMBLY
1997 EXT 600 - HYDRAULIC BRAKE CONTROL ASSEMBLY
1997 ZRT 800 - HYDRAULIC BRAKE CONTROL ASSEMBLY
1997 ZR 440 - HYDRAULIC BRAKE CONTROL ASSEMBLY
1997 THUNDERCAT MC - HYDRAULIC BRAKE CONTROL ASSEMBLY
1997 POWDER SPECIAL - HYDRAULIC BRAKE CONTROL ASSEMBLY
1997 EXT 580 EFI DLX - HYDRAULIC BRAKE CONTROL ASSEMBLY
1997 ZRT 600 - HYDRAULIC BRAKE CONTROL ASSEMBLY
1997 ZL 440 - HYDRAULIC BRAKE CONTROL ASSEMBLY
1997 THUNDERCAT - HYDRAULIC BRAKE CONTROL ASSEMBLY
1997 POWDER SPECIAL EFI - HYDRAULIC BRAKE CONTROL ASSEMBLY
1997 EXT 580 EFI - HYDRAULIC BRAKE CONTROL ASSEMBLY
Replaces 0602-831
