its that time of year again. what is the torque spec for the driven clutch?
thank-you. a little bit of frozen stuff this morning
NY AttakGT
Primary clutch (22mm bolt)- First torque to 85 ft/lb to set clutch on shaft, then back off (loosen) and re-torque to 43ft/lb.
Secondary clutch (14mm bolt)- Torque to 46 ft/lb
Helix/Cam bolts on secondary clutch- (three 12mm nuts) Torque to 17 ft/lb.
Hope this helps.
--Steve (O.C.)
Hope this helps.
--Steve (O.C.)
