ShootToThrill
Can the nytro be adjusted through the gauge like we can on the apex? If so how? Thanks
rideblue
- Mar 17, 2005
- Buena Vista Colorado
- www.mountaintechbv.com
It can be adjusted and it is the same steps as the Apex and Phazer. The light green wire that you need to ground is in a single white bullet connector taped to the out side of the wiring harness down by the ECU.
redsnake3
what exactly are you guys talking about?
Kråkan
CO adjustment
errol
- May 24, 2003
- Quebec, QC
- 2018 SW B-TX LE 50th
I've done it last night! Pretty easy!
Set all my cylinders to -10
Errol
Errol
ShootToThrill
Just installed a mbrp muffler gotta ride it now to see if it needs an adjustment. Anyone have to make a change after a muffler swap?
yukon yamaha
- Jan 30, 2008
- WHITEHORSE, YUKON CANADA
- 2008 nytro custom! 2014 viper custom
i did mine and with a mcx turbo put them to -15 runs like a top
Bodacious
Anyone try adjusting using the OEM exhaust. Mine seems to loab at an idle, as if it is on the rich side.
SnOrIdEr
Can anyone tell me how to do this on a phazer?
Nytro40th
- Sep 19, 2007
- Amherstview Ontario
- 2014 SR Viper RTX SE
dieselnick
What is the best setting for a stock phazer mountain lite ?
Nytro40th
- Sep 19, 2007
alot of it is trial and error, your best bet is to talk to other phazer owners as I do not have a clue myself.
