Fun stuff to do to the Turbo sled this weekend!!!
Skydog
Byron, IL
Going to run coolant back to the turbo!! Put in my new adj fly weights from Dalton's patented quick adjust flyweights QACA/ DTYA-2 (79-86.4g).
Then putting in new Woodys Steel Chisel Tooth and angle backers. Then install a Alcohol injection it will be four jets in front of each carb with a fail safe 12 volt signal will trigger if it is not flowing. Going to be fun!!! :Rockon: :Rockon: :jump: :rules :-o
Skydog
Hope she stays alive.Keep a close look on the a/f gauge to be safe.Good luck
Me to, if not motor coming out for a BIG build!! :) :)
Thank you Skydog
Tell me Skydog - are you pushing it to justify your long wanted built engine huh then you can have knife edged and stroked crank, ditto rods:-) just kidding. Good luck on your install and tell us all about it when you have got some seat time.
rxrider
Will do man i hope the Alcohol injection works like it should it could be the best thing yet for us!!
Skydog
Some one got to test it .I think it should be you skydog.Man,you must love boost.
Sweet!!! It is coming! CLutch all done, and about 50% of the kit is on. I have about $500.00 in the kit know i bought the fail safe kit. Where if flow drops it will trip a seliond to open wastegate! TRICK STUFF!! :) :)
Skydog
Looking good - Nice having a safety feature if something goes wrong. Pics please :-)
OK i will run down to the barn and get some pics!! She is 95% done now!! All i have to do is mount the tank in the trunk!
Skydog
Pics!
This is going to ROCK!! :Rockon: :Rockon: ;)!
Pic
:Rockon: ;)! :jump: :-o
The pump!! The yellow deal to the right is a valve to stop it from dripping.
