Saw this on Facebook Yamaha Snowmobiles, USA
TECH TIP: Adjusting GYTR Dual-Clicker shocks
The standard setting of GYTR shocks on the FX Nytro and FX Nytro XTX is 6 clicks out for compression and 11 clicks out for rebound; however, both settings are widely adjustable to suit your ride preference. Compression and rebound dials should be adjusted separately-- only1-2 clicks at a time-- until you find a setting you like.
Eagle1
It really is amazing how a few clicks can make such a difference.
I think most people , my self included, kind of forget this when out riding. Trail conditions change throughout the day so don't be afraid to pull over and make a few changes.
KHEXX
MrSled said:Saw this on Facebook Yamaha Snowmobiles, USA
When you say out...what exactly do you mean? Sorry mine ive left at the stock setting, and any explanation as to what they do when adjusted would be appreciated!!!
The term out is from tight (not over tight but when it stops turning clockwise) . 6 turns out would be 6 clicks counterclockwise. You can feel the clicks as you turn them. Make sure they are the same on both sides.
birkebeiner
- Jul 27, 2009
- Norway
- Norway
- 2015 Yamaha SR Viper X-TX
And with x turns out, I guess that means you first turn it all the way in clockwise, until you can't turn anymore, right? And out is then counterclockwise until you're satisfied?
And what does the shock do when you turn compression and rebound out, from all the way in?
Compression all the way in (clockwise) = no compression at all, i.e. soft damping? Or opposite, i.e. firm/stiff damping?
Rebound all the way in (clockwise) = fast rebound, i.e. the shock returns to full stroke quicker? Or opposite, i.e. slow rebound?
My Rock Shox fork on my mountain bike has turtle and rabbit signs to show which way to turn the dials. Trying to read up on how suspensions works
Compression: All the way in would be harder or more force to compress... harder it will stroke less or be firmer.
Rebound: All the way in would be firmer as well or it will return slower... so if you want it to return quicker you want to soften the rebound.
The more you turn the knob in the more you close the valve and that will restrict fluid movement.
birkebeiner
- Jul 27, 2009
- Norway
- Norway
Thanks Mr
Also found this vid on youtube that explained it
http://www.youtube.com/watch?v=kQ9DGECizzk
birkebeiner
- Jul 27, 2009
- Norway
- Norway
A few more questions
When someone says increase rebound = turn out / counterclockwise the rebound dial = faster rebound
and
reduce rebound = turn in / clockwise the rebound dial = slower rebound
Increase compression = turn in / clockwise compression dial = firmer damping
and
Reduce compression = turn out / counterclockwise compression dial = softer damping
Right?
and
and
Right?
birkebeiner said:A few more questions![]()
and
and
Right?![]()
Correct!!
birkebeiner
- Jul 27, 2009
- Norway
- Norway
redrx1rkt
- Apr 20, 2005
- South Shore of Lake Ontario
- www.snowdevils.net
The question is - which dial is the compression, which is the rebound???? (from left side of sled, on knees, looking at skid)
redrx1rkt said:The question is - which dial is the compression, which is the rebound???? (from left side of sled, on knees, looking at skid)
Compression dial is almost always on the remote can and if it has rebound adjuster it will be at the base of the shock.
redrx1rkt
- Apr 20, 2005
Base of the check? You mean at the bottom of the shock (closest to ground)?
BTW, thanks for responding so quickly!
redrx1rkt
- Apr 20, 2005
By remote can, do you mean the reservoir on the shock? BTW, it is a 2008 Nytro RTX.
redrx1rkt said:Base of the check? You mean at the bottom of the shock (closest to ground)?
Yes, you are correct... fixed my fat finger error.
