Handlebars
Tridav3
Yellowknife, NT, Canada
I need to put in new handlebars for my Nytro. Anyone have any suggestions? I flipped going 120 km/h and bent them last winter.
The OEM bars from the Arctic Cat SnoPro 440 (I think the same bars were also used on the F7).
I had them on couple of sleds and I loved them.
The pictures show these bars on my old -05 RX-1.
Though, if you put them on the FX Nytro you will need a higher than OEM riser because the bars themselves has got zero rise.
x2 on the apex bars, but you'll need a taller riser to match the stock height. Also, not all the apex bars will be warmer. You have to get the ones before the update in '06, which can be tricky to find. I just bought the cheapest pair of used ones I could find and got a Yamaheater- no more cold hands and better bars! :)
Thanks alot. How are the hand warmers on the SnoPro?
Yeah that crash hurt alot. Luckily I did no damage to myself though.
Will aluminum handles bars affect my hot-grips that much? Will the heat dissipate into the aluminum?
Yes, the aluminum bars will soak the heat up. If you want to go aluminum for what ever reason, make sure to get carbonfiber wraped ones, thateill insulate the heater from the aluminum and help with the heatsink issue. Your best bet is full carbon but then your getting $$$$$.
