Nytro0316
Hey guys looking for for pro's and con's and suggetions. I just purchased a 19 tooth for my 09 Nytro SE. Thats only 2 teeth down from factory. I love the low-end and the mid range. I hardly ever run wide open down the trail, and I know from dropping two teeth, I'm probably going to lose 10mph from the top end. I dropped two teeth on my viper and it ran great with my triple pipes. Just looking for suggetions, because looking at everything you have to take off,it's going to be a one shot deal.....
sleddingfarmer
That is what I ran out west. You can still run stock chain.
I still saw 90 mph on my speedometer, at about 8000 feet elevation.
Nytro0316
Did replace the gear yourself? If so any problems I should be aware of?
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
I'm also going to change my top gear to a 19 tooth.
My friend runs it on his MTX, and it works very well.
The only thing that is a bit tricky is to get the reverse "arm" correct when mounting it together again. But there are several good guides on this forum for that.
What is stock gearing on the RTX? Is it the same for all 08-10 models ?
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
thats a tight bend...you can do it but it loses a efficiency etc
Id explore the lower gear even though its more costly
sleddingfarmer
Nytro0316 said:Did replace the gear yourself? If so any problems I should be aware of?
Its pretty straight forward, just remember how you took it apart, and put it back together the same way.
Getting the reverse back together was the worst part, but it isn't too bad if you take your time.
I printed off a couple of pages showing how the whole chaincase went together, so I could make sure i was putting it together correctly. It helped.
arteeex
Taking digital pictures as you go is easier than remembering things.
sleddingfarmer
arteeex said:Taking digital pictures as you go is easier than remembering things.
I tried that too, but I forgot to take the pictures, so it didn't help very much
arteeex
I considered adding that little detail about remembering to take the pictures.
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
sj said:thats a tight bend...you can do it but it loses a efficiency etc
What do you mean with" that its a tight bend"?
I dont understand.
Thanks..
Nytro0316
21 teeth is the top gear.....
09nytro
that means when u adjust the chain ( the chain adjuster bolt ) the chain will bend alot more than it was stock so if u change the top & bottom it will b more like stock form
stopdropanroll
- Oct 8, 2008
- Fall River WI
- www.styleonecustommotoring.com
Dimebag said:sj said:thats a tight bend...you can do it but it loses a efficiency etc
I dont understand.
Thanks..
I think what he really meens is that gear has a very tight radius and that its a sharp bend for that chain to go around.
SledFreak
- Feb 7, 2005
- Ontario. Canada
stopdropanroll said:Dimebag said:sj said:thats a tight bend...you can do it but it loses a efficiency etc
I dont understand.
Thanks..
hence, which makes it less efficient, which may result in a loss of top speed.
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
Ok. But isn't the point of installing a smaller upper gear to improve acceleration and loose a bit top speed?
