mjaremko
Suspended
Some one posted this fix about six months ago, just wanted to say thank you to whoever it was and post a photo for the rest that havent done it yet. It is very simple and it works.
The fix is the small O ring on the left side of the roller bolt, click on photo to enlarge.
mj
mj
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
So for us clutch newbies is it really as easy as loosening the bolt installing the O ring and re-tightening?
If so what size O ring and what torque on re tighten?
Yamadoo
Yamadoo
mjaremko
Suspended
Yes,
Its as easy as removing the nut, placing a small "O" ring that I bought at Home Depot on the bolt and re-installing the nut. My torque wrench doesnt go that small so no idea on the torque.
mj
mj
NFLD-Nytro
Nice! I've got to try that.
BADSLED
- May 13, 2004
- Syracuse, NY
- 2012 Nytro MC Xpress 270
2011 Apex SE
2021 Sidewinder LTX SE - SOLD
I tried it and it eliminates the rattle. However, I have been unable to keep the o-rings inplace, they were gone after the first ride. Must be the harmonics of 3 cylinder engine generate more rattle then then Apex models. A small washer washer would be ideal.
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
Brilliant! Thanks for sharing
RIKMAN
- Feb 21, 2008
- Val d'Or, Qc
- 2020 Srx
BADSLED said:I tried it and it eliminates the rattle. However, I have been unable to keep the o-rings inplace, they were gone after the first ride. Must be the harmonics of 3 cylinder engine generate more rattle then then Apex models. A small washer washer would be ideal.
X2.....
mjaremko
Suspended
Maybe I got better O rings because mine have been in around 300 miles and look fine. I used small ones, barely large enouph inside diameter to fit over the bolt, then crushed it down hard with the bolt.
mj
mj
yooper1
I had mine running tonight and all the covers were off and I said to my buddy, OMG is the ckutch loud!! Thanks, I'll add those tomorrow!
09nytro
I also tried it , but can't keep the o rings in they came out on first ride but it did work for a little bit
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
I posted it...it was my idea....you can get a thin nylon washer to act as a keeper for the O ring...
trailbreaker
I used the thin nylon washers #10's from lowes and put them on both sides . I have 700 miles on them and no problems and they are still there.
Straight_up_XTX
I'm going to try this for sure! Finally a nice cheap easy fix! Lol!
Old Thumper
Nylon washers AND O-Rings? Or just the washers?trailbreaker said:I used the thin nylon washers #10's from lowes and put them on both sides . I have 700 miles on them and no problems and they are still there.
mjaremko
Suspended
sj
Thanks Dude !!!
Thanks Dude !!!
- 118K
