Curve Industries
TY Advertiser
Does your FX Nytro have a loose front end? Replace the OEM plastic bushings with a Curve Industries high performance, self lubricating Oilite bronze rebuild kit!
This kit will allow you to replace your worn out plastic a-arm bushings with reliable and self lubricating bronze Oilite bushings. Machined to precise tolerances, these bushings will simply press into your arms with a clamp or soft jaw vise.
About Oilite Bronze:
To provide extra-slippery performance, Oilite bronze is slightly porous and impregnated with oil. The oil acts as a cushion between the bearings and your shafts to add wear and shock resistance.
FX Nytro A-Arm bushing kit consisting of the following items:
Item Qty Description
1 12 Oilite Bronze Bushings
Curve Oilite Bushings Are Made In The USA
Check them out in our store:
http://www.curveindustries.com/shopexd.asp?id=262
- Sean
www.CurveIndustries.com
- Sean
SSX600
- Feb 13, 2010
- Richland Center WI
- 2010 Nytro XTX, 1997 Mtn Max 600, 1998 SSX600, 1975 SM292F, 1987 Inviter
Wish someone would make a oillite bushing kit for the rear suspension also.
Curve Industries
TY Advertiser
We haven't had any issues there but we'll have a look and see what can be done!
Specifically, what problems are you having in the skid?
- Sean
- Sean
SSX600
- Feb 13, 2010
Plastic bushing wearing out on the shocks and all the pivot joints. Maybe the shock bushings get to much abuse to be made out of bronze not sure. Would be something to look at would sure cut down on the pre-season overhaul if these bushings would last longer.
Curve Industries
TY Advertiser
- 7K
