Maurizio Benelli
Can anybody tell me what are the differences between those? They don´t have the same part numbers on Apex and Attak, so there must be some differences?
I´m having a problem with my extended Apex. I extended it from 121" to 144" and now the track tightens like hell when the suspension compresses.
There are only couple of inches of travel and then the track prevents the suspension from compressing.
I´m thinking of getting an Attak rear pivot arm and rear shock to get me through this season. Next season I think I´ll have a completely different skid.
KevinS
On an Apex I believe the upper wheels are attached to the rear arm. On an Attak they are on a separate shaft. Here is the rear arm from my Attak that I sold last year. I also don't think the Apex rear pivot arm has those pieces that rub against the track.
KevinS said:On an Apex I believe the upper wheels are attached to the rear arm. On an Attak they are on a separate shaft. I also don't think the Apex rear pivot arm has those pieces that rub against the track.
Yep. That is correct
Maurizio Benelli
Thanks, Kevin. You´re right, on an Apex the upper wheels are attached to the rear arm. I´ve never spotted that difference before. Hm, think I just move the upper wheels backwards at first and see what it does.
Would you or anybody else happen to have any measurements how far the upper wheels are from the rear arm on an Attak?
Maurizio Benelli
Maurizio Benelli said:Would you or anybody else happen to have any measurements how far the upper wheels are from the rear arm on an Attak?
Anyone?
Maurizio Benelli
Thanks a lot, this helps me! Could you please measure how low the 136 skid upper wheels bolt center is from the heat exchanger?
The center of the bolt is 11\16" below the heat exchanger measured from the bottom of the exchanger. If you can get a factory mounting plate from Yamaha.
Added measurement to the pic above
