HID Testing
steiner
Staff member
Moderator
Niverville MB Canada
Found a way to test the HID's without running the sled.
Find the 20 amp fuse marked "Head" This is the power for the headlight circuit.
Remove the fuse. Insert a cotter pin or a small blade screw driver on the cold side of the fuse.
This side has no power when the fuse is out and the sled is running.
Use a jumper from the battery to the cotter pin. The headlight circuit will power up and you can test and check
all your connections and even the headlight aim with the sled off.
