Studroes144
- Oct 30, 2013
Just finished drilling my track for studs. I've always liked the V pattern and every other outside lug in an alternating pattern. 48 lugs on the 137" track. I do 3 holes per row and then on every 4th row I put 1 stud right in the center of the track if that makes sense. I use 1 stud in the center and then on the next lug put 2 studs slightly apart until it forms the V. That lug that has the stud right in the center is the same lug that has the two studs at the widest point(not the outside lugs, still on the inside bar). Not sure if anyone else has ever used this or plans on using it but it has worked great for me in the past. It makes for a complete footprint on the ground with all the studs. Total number of studs used is 156. Will be using 1.5" studboy power points with tower nuts and square backers. Will post pics tomorrow night when it's complete
