Took the muffler off for my 300mi chaincase adjustment. Chain tensioner took 2.5 turn with fingers to tighten and 1/4 turn back. Nothing abnormal there. I then took a look around since I never had muffler off. Came up with two rub points. This one is almost through. Is only a vent line I believe but still.
09nytro
man , i never looked at anything when i took off my muffler to adjust chain , looks like i will have to pull it back off to have a look at that stuff
thanks for the heads up !
freelance
- Apr 15, 2013
- Manitoba, Canada
- 2014 Yamaha SR Viper XTX SE
Anybody remember who was making the copper muffler gasket ?? I'm thinking if the chain needs to be adjusted every 500 miles that's going to be alot of gaskets which I believe currently are not available. Odds are you're going to destroy a few gaskets with this procedure.
Mike1157
- Jul 24, 2013
Copper Gasket
Hurricane Performance
- Apr 14, 2003
- Hessel, Michigan
Good to know Steve!
I saw you and your little ones heading toward the river on Tuesday.
Suckur
A guy on HCS had his new turbo burn to the ground from an oil line snafu. I found my injection line behind the muffler almost worn through. Yikes!
larrypolaris
cannondale27 said:When I took off muffler gasket split. I am going to try reusing since looks pretty good to me. Mine also had 3 bolts. I bet the fourth is for alignment at factory.
My gasket split also. They looked fine. I re-used them.
It looked like I had two gaskets on the joint. One on the muffler, one on the pipe. Then the thin part that split.
I used a bungee cord to hold the pipe out of the way so not to damage the gaskets when re-installing the muffler.
Good tip on the spring. Mine took a flight to never never land. Long magnets sure come in handy.
new rob
- Oct 18, 2009
- peterborough ontario
- Viper rtx
What about a little high temp silicone???
I dont think its needed on gasket. No leaks. Just reused one on there. Maybe it is designed like that.
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
I put an extra bolt in my muffler flange. Just didn't think it looked right with that extra hole.
canadianhunter
For the spring I made a tool with a small hook on the end from apiece of wire, takes only seconds to unhook and hook up the spring. Accually had the tool from the 2 stroke days from use on the exhaust springs.
Good tip on the use of the bungee cord. Don't know what I cut my thumb on, but had blood every where.
