After sitting a long time it will be hard to start because the fuel pump has dried out, which means that there will be no suction to the gas tank.
The solution: force gas into the fuel pump.
How to do that:
Open the hood, remove the clutch cover. Locate the clear hose that is fitted onto the FRAME just behind the secondary clutch. Remove it from the frame, CLEAN IT, blow into it until you can't blow no more and hold your finger over it. Open choke full, leave throttle closed, and turn the key. Should start really easy.
