IFlyEm
Can't get my warrior to start. I have never had an issue no matter what the temp before. Now she just turns. Sometimes she'll fire and run at idle for a few secs or she'll just backfire. Any ideas?
check your plugs.
they might be fowled. if they are ok check the spark. if it is yellow you have a bad coil. spark is suppoesd to be fat and blue.
check the oil too. if you smell gas off of the dipstick it flooded and needs the oil changed.
z28rx1
Sounds like its flooded, hold the throttle wide open, untill it fires,Duhh, an keep it goin! Ive had it happin.
yamaslob
New set of plugs. Had the same thing happen to me, from starten it up and letten it run just for a few mintues to show the buds bam plugs gone.
stumper
I'm with maim on this one. Check to see if you've gassed up the oil, because if you have, your compression drops and you won't get it going, new plugs or not. If your oil is "gassy", change it AND the plugs, as the plugs probably fouled along the way as well. Good luck!
IFlyEm
OK I checked the oil and it doesnt seem "gassy." I pulled the plugs and checked the spark. They were a little wet so I dried them. The spark looks decent and its blue not yellow. Still same result. Nothing at all until I crack the choke then she'll backfire. I am at a loss. Should I cut the fuel off and try to burn out any residual fuel? NOt sure why it would be flooded either. Ran great last time I rode her now dead as a doornail
snowhawk
- Jan 25, 2006
Maybe I have Your Answer
A freind of mine rode his 04 Warrior on a Saturday and Sunday we went to start it and it did the exact same thing you are describing. It was very cold that Saturyday night. It was a low battery. We hooked up one of those baterry packs and it instantly jumped to life and idled and ran normally. For the rest of the day it ran great. With the symtoms we never expected it would be that. Give it a try and see what happens.
Snow Hawk
Snow Hawk
Convert
- Apr 14, 2003
- Lakeville & Nevis, MinNoSnowta
Maybe your pilot jets? mine ran pretty similar ran like crap on the low end ran ok full throttle but could'nt get er over 8500 cleaned the carbs good as new.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
First, try a new set of plugs. If it doesn't help do as Convert says and check the pilot jets. This happened to me as well, with dirty pilots it won't run.
IFlyEm
SHE'S ALIVE
Changed the plugs and she fired right up. Funny thing is the old plgs werent fouled and I cleaned them and dried them.
