I need to disable my TORS to be able to use my Powermadd left-hand throttle. I remember doing this with my RX-1 (carbed). How does it work with fuel injection?
It is similar to the RX1 in that you disconnect two wires and plug them back into each other on the same side of the ciruit. Under the headlight pod you will find a rubber boot with several wiring connections in it. There are only two of these wires that are singles and that you can disconnect and plug back into each other. If I remeber correctly they are brown and black. The owners manual mentions this, but has a pretty poor description.
