CHAIN CASE GEAR OIL
SharkAttak
East Falmouth, Ma.
i'm doing my 500 mi. oil & filter change on my phazer fx and wanted to change out the chain case oil, can someone tell how much to put in the case the attak takes 8.5 oz. is it the same and also is the drain plug in the front or the backside of the tunnel?
yamaha sells the oil in a little bottle, I'm not sure of the size but dump it all in and it should fill you up.
Using a kitchen measuring cup, measure what comes out and put that much back in. :Rockon: (Assuming, of course, the oil was up to the proper level in the first place.)
BV1 said:
Manual says dont change until 4000 km?
-Steve
did the oil & filter change the other day and had everthing ripped apart, why not change gear oil too, can't hurt, adjusted everything and checked out everything so i don't have to worry about it till next fall ;)!
