Rode my sled for the first time today. Put on 26 miles in knee deep powder snow with a base on the bottom, 22 degress and sunny.
The conditions were okay for putting around on roads and the Pipeline ROW but you still had to be careful as rocks were well hidden under the powder. I was fortunate and didn't do any damage but you easily could of had you gone off trail.
POWER
My first impression of the sled's power was a bit underwhelming. That soon changed once I packed down a long straight away on the ROW and held it wide open for a couple passes. It definitly feels snappy and pulls pretty well. It is a lot like my Vector in that there is no hit, just smooth power propelling you forward. The fastest I saw on the guage was 84 mph. The conditions were not at all ideal for speed runs. Seems like it would get to the 70's and 80's pretty quick and then run out of steam. I'm sure is due to the gearing since like my dealer sled, the sled is made to be quick like a YZ and not fast on top end like an Apex. As the day progressed and my trails got more packed down ( I was the only one riding in the area) the sled felt more and more impressive. I was kind of relieved because my very first impression when breaking trail was that it felt a bit weak. I knew it wouldn't be, yet that was my impression.
SUSPENSION
I was surprised by how stiff the front end was. The sled is completely stock. I didn't change a single thing from the way I picked it up from the dealer. There were no whoops to hit or jumps to take so I couldn't work the suspension. I noticed the stiffness in the front end when riding over frozen tire ruts on one of the roads. I was happy to see that the front end was stiffer than I anticipated since more often than not, I have to install stiffer springs. The rear suspension seemed fine but I never even bottomed it out because there was nothing to hit. It seemed to transfer pretty well but with the dry snow, the sled spun the track so you couldn't get a good feel for how much it would pull the skis.
HANDLING & ERGOS
I think I was most impressed with the handling. I've only ridden a REV and handful of times and those were few and far between. Getting used to the rider forward took me a few miles. My Vector is set up with a hi-rise Boss seat and the forward steering post mod so I knew I would like an even more rider forward sled. The Nytro is nothing like my Vector. The Nytro is so comfortable and nothing gets in your way or feels out of place. I was surprised to find that I liked the stock bars since I was sure I'd want the RTX steering post so I could rotate riser and bars even more forward. I never even felt an urge to put the bars more forward so that was nice. The seat is really slim and the sled feels great either standing or sitting. I can't wait to race this new chassis because I fought my Vector in the corners and through the bumps. I was really excited when I railed around a couple high speed corners and the sled didn't try and lift the inside ski. It feels pretty stable at speed but I did notice it felt a bit twitchy when letting off the throttle and and hitting the brakes to slow down. I think it is from all the weight going forward onto the skis and with me not being used to a rider forward sled, it was more noticeable than my Vector or a traditional sled.
I was able to carve a bunch in the powder and the sled is really easy to pull over from side to side. Definitely easier than my Vector. The stock skis really suck for powder but we all know that. Next time I head up I'm going to install the 6" wide UltraFlex III's I had on my Vector.
Basically the Nytro is way better and easier to ride agressivly than the Deltabox chassis. I doubt that comes as a shock. During my ride I thought to myself how fortunate it was that I bought the new chassis for racing this year because I didn't know what I was missing out on with the rider forward. I was also happy with the side panels since I banged my knees on them a bunch and it didn't bother me since the panels are soft and tend to give. I purposly didn't wear my knee guards because I wanted to take it easy. I recall banging your knees was one of the complaints about the REV.
LIKES
The wind protection wasn't too bad. The hot grips and thumb warmer work awesome and the handguards do work. I wore thin, Fly 907 gloves and my hands stayed warm. I actually pulled a glove off while riding to see if hot air came out of the vents and it certainly does.
No ice water came spilling out from under the seat like I read about happened with the Phazer. The running boards worked pretty well although I still prefer the heat exchangers mounted underneath. I definitely had to do a bunch more kicking to clear them off then I did on my Vector. But, the holes worked fairly well at letting the snow through and my feet rarely slipped off.
The exhaust note is throaty but quiet. I like quiet sleds and after having to wear earplugs with the Hauck exhaust on my Vector, I think I'm just going to leave my exhaust stock.
One thing I didn't even think about until now was the reduction in engine braking. I didn't notice anything while riding and it didn't even come into mind. Maybe it was because of the loose deep snow or because it was my first ride of the year. Whatever it was, it was a non issue.
DISLIKES
I don't care for the guage since it is small and harder to read than the one on my Vector. I think they made a mistake by not running the heat exchangers under the running boards. That was one feature I like about my old Indys and with my Vector. The stock skis suck #*$&@ and are worthless in deep snow. I wish the sled came with a 10 gal tank, the 7.5 was a mistake. I don't have any MPG info but I started my ride with about a half tank and had the fuel light come on at the end of 26 miles. My Vector's light was very conservative and I'm sure the Nytro will get good milage, however, I'd much prefer a larger tank. I guess I'll have to see what they come out with next year and what the aftermarket is doing. I really do like the slim feel of the sled so it might be one of those things where you can't have it both ways?
Oh, one wierd thing I noticed was that my left boot was soaked at the ed of the ride. My right boot also got wet but it was like something was melting was dripping onto my left foot. I also noticed the left running board was more difficult to keep clear than the right. I was thinking about it and I think because warm air comes out of the vents it also melts snow onto your feet. I'll have to keen my eye on this. Could have been that since I like to carve to my left I just accumlated way more snow on that side. Don't know for sure, but I made sure I wore the exact same riding gear I've worn for the past couple seasons and I never got wet boots on my Vector. Kinda wierd...
OVERALL
I am impressed with the sled and have no reservations or second thoughts about my purchase. You can tell the sled is lighter both when riding it and when horsing it around on the trailer. It is definitly lighter in the front end than my Vector. I notice this when having to lift the front end up & over to better line up with the ski clamp. The sled is very comfortable and reminds me of a sport quad when going around corners. I can't wait until we get more snow so I can really ride it hard and see how it feels through the bumps and in the air.
Oh yeah, trying to keep the sled under 6,000 RPM for the first 100 miles is going to be very difficult! The sled wants to rev.
POWER
SUSPENSION
HANDLING & ERGOS
LIKES
DISLIKES
OVERALL
