82SRX500
- Oct 6, 2005
- Hampshire, IL Near Chicago
- www.toizrit.com
Guys, as some of you know, I am about as loyal of a Yamaha guy as you can get. I am the 40th Anniversary of the Snowmobile author and have one hell of a Yamaha collection so don't take this as a slam email. I am completely at a loss on this Nytro FX RTX Anniversary.
I have been riding in a group of three Nytro FX RTX's all week. I have done an amazing amount of tuning on the front and rear suspensions trying to get this sled to perform for trail riding. Three of the guys working on the sleds with me either work at Yamaha dealerships as mechanics or have owned a Yamaha dealership for 30 years.
Maybe if I was jumping six footer's the sled would be great, but in my opinion this sled is terribly stiff. I weight 155 the other two people are 155 and 230 pounds. None of us are happy. I ride very fast, aggressive, on trails in Northern Wisconsin. The sled just does not perform in my opinion any where near what it should. Some of the other guys I am also riding with have Rev 600 and Rev XP 800. Both sleds stock rail on the curves, they absorb the bumps front and rear. These guys are not drinking around all day trying to get their sleds to work. And they are not adding aftermarket skis to their sleds.
What I have done to get this sled to ride like a normal high performance trail sled that has created some improvements but no where near enough.
Rear Suspension:
1. Limiter strap 2 holes.
2. Front shock, spring adjusted down to 1 thread showing off set the 2 holes on the limiter. Big help.
3. Rear springs set to SOFT
4. Rebound set to three clicks back from stock
5. Dampening on front and rear shocks set all the way out to where you can not turn them any more. Sorta helped.
6. I was running 144 studs standard pattern inner and outer belts. Removed the outer belts to try and get this thing to stop pushing even after all the stuff I have already done. Some benefit.
Front End - I have the RTX but installed the base Model Clicker shocks
1. softened the front springs by 6 mm. Big help
2. Dampening. A click or two back from stock
3. Rebound 2 clicks forward from stock to eliminated roll
4. Installed 8" Woody's Dually carbides to help eliminated push.
After experimenting with all of this the sled is still a brick
Guys, the bottom line is I am at a loss to what it will take to make this sled absorb bumps and ride comfortably?? All of these changes were done over five days with each day performing different changes. I again, only weight 155 with gear maybe 185. This is completely to the point of being unacceptable to me to have to do this much work on a sled to make it ride like it should on rough trails. It should absorb bumps with what I have done. It does not. It just does not absorb. It is a brick.
So, now I am down to this. Calling Pioneer Performance to see if they can revalve these shocks to a calibration that a normal every day consumer will appreciate or at least one who weighs less than 230 pounds. Or attempting to put a mono-shock rear skid into this sled.
I have run Vipers, SRX's and the Apex the past ten years and all I can say is this sled is just not right for someone who wants to ride aggressive trails with chop and bumps. It is designed to one thing well, Stand up and jump six foot drive ways. My one friend just put the Nytro he bought away and now is driving his old Apex again.
What I do like is the lightness, ride position is great like the Apex was, the engine performance is awesome. Hand warmers are weak as we all know. Installed the 14 windshield now after two days of have snow all over the inside of my helmet. snow flap is lame, gets wedged up with ice and then blows snow all over your friends behind you - or rocks.
So, I hope I am not the only thinking this. I hate beating up something I have invested a lot of money and pride in but something needs to change. ANY OTHER suggestions on what to do to this rear skid?
Rear Suspension:
