Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
- www.jannettyracing.com
I just got off the phone with my Performance Distributor.
For all you guys having oil consumption problems with Bender Rear Mount GT2554R Turbo, we now offer an exchange program for the Center Housing Rotating Assembly or CHRA.
Normal Map Pricing is 790.99 for a New CHRA, you send me your old one and if deemed acceptable you get 200.00 back.
Acceptable means No Wheel damage and or severly wobbling shafts.
Keep in mind that all of these failures are directly related to the fact that there is no water running through the CHRA on these Rear Mount Turbo Kits.
So If you have one and it is working well Add the Water Lines.
I have Water Line kits in stock to hook them up.
Call to order 203-753-7223
TT
What will be the price on a water line kit?
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
TT said:What will be the price on a water line kit?
125.00 Earls fittings and hose. top quality
sledheadgeorge
- Apr 28, 2003
- Which one? I have 6
Ted Jannetty said:TT said:What will be the price on a water line kit?
Can this line be hooked up to a MCX rear mount?
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
sledheadgeorge said:Ted Jannetty said:TT said:What will be the price on a water line kit?
I am sorry I don't know for sure, can you Post a picture of your turbo.
If it has water ports and they are 14 x 1.5 mm thread or other I should be able to offer you something.
Ted.
sledheadgeorge
- Apr 28, 2003
I don't think the mitsubishi has any water ports on it. Might just have to go with a bigger turbo.
Otis RX
I run Teds water kit as well as the oil lines on my 2560R. Works great!! My Bender 2554R had the oil problem and it killed it very quickly.
Best to run both. My 2 cents
sneakattak88
is the kit easy to install? im interested in this kit, makes sence to me, guess i will be ordering a kit,,
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
sneakattak88 said:is the kit easy to install? im interested in this kit, makes sence to me, guess i will be ordering a kit,,
Yes you have to pull the seat and heat sheild, run the hoses up the left side of the sled, and hook in to the Carb Heater Hose.
Remove the 6 inch heater hose, hook one hose to the carb and one hose to the water pipe.
Ted.
