STINKFINGER
Ok, Can I get the part and fix this myself ? Has anyone done this ?
It appears that all you would need to buy is the plastic cover and plug.
I have no idea how to get it off or what lies beneath.
some help is appreciated.
RTX Meirda
ditto
welterracer
Im guessing its not that easy..
Anyone? I have the same problem, wires are broken at the plastic cap. The cap swirvel but can't get it out.
Port-Parts
TY Advertiser
- Sep 18, 2003
- Port Washington Wi
- www.portyamaha.com
- 2012 Nytro RTX
2018 Sidewinder BTX SE
The plastic cap is actually an electronic solenoid and has a clip holding it into the shock body however the clip cannot be accessed to remove it. What you need to do is pry up on the edges of the solenoid and normally the plastic around the clip will break allowing you to remove and replace the solenoid. From experience some come out pretty easy others can be a real pain to get out. If your not planning on replacing the solenoid don't try removing it as it will break upon removal. The solenoids are sold through Yamaha and cost around $175 even though they are not listed on the microfiche you can get them. We normally stock the solenoid if anyone needs one.
Thank you for the info.
FYI
Just ordered the solenoid (101$ cdn).
Port-Parts
TY Advertiser
- Sep 18, 2003
- 2012 Nytro RTX
Yummy - thats a great price considering its Canadian. I think we might have just found the first part cheaper in Canada than the US! Do you have the part number for the part your getting?
Yes, I'm also VERY surprise of this (Maybe the part is made Canada..ahahaha). Should get it by tomorrow, will let you know.
Yummy
Yummy
POB88
Do you have A part# for it?Yummy said:FYI
Did it come with a new wire?
Thanks...
LJ 452
POB88 said:Do you have A part# for it?Yummy said:FYI
Thanks...
Yes, the solenoid comes with his wire and plug (solenoid side only).
I don't have the part number. Since then I have switch to ZX2 suspension.
Good luck!
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
