powderlites
- Sep 5, 2005
- Sicamous, BC Canada
- www.powderlites.com
Skydog
SWEET!!! The time is getting close!!! For my Powderlites kit to get here!!
Skydog
Skydog
powderlites
- Sep 5, 2005
powderlites
- Sep 5, 2005
Skydog
Thank you Dave!!!
Skydog
Bring on the snow!!!
powderlites
- Sep 5, 2005
Skydog
Here is a map i have been working on. It is a stage 1 PL 1200 doo. 800 feet 10-11psi studder at 3,000 rpm and rev limit up.
Thank you Skydog P.S. Who ever trys/runs this watch your AFRS at WOT!!! This map will be adj. in a few days have not had time but best map i have run in my Doo yet!!
Skydog
Going to do some tuner bike to this in a day or two!
Skydog
Skydog
Skydog
Tuner bike done up to 15PSI with 110 Octane fuel. At 800 feet will put up asap!!
Thank you Skydog
Thank you Skydog
Skydog
Update rode sled last night 1st time with wideband on with the tuner bike off sled. It made the bottom too lean the 5500rpm range going to make some changes to it. Then test and ride.... Then put map up i should be done with the 1200 Doo map then up to 15PSI.
Skydog
Skydog
Skydog
Well here is my best map so far, of course i will keep making it better as the year goes on. Just keep in mind no two sleds are the same. They can be close.......
800 feet 12PSI no boost running...
12.5-13.1
WOT 11.5-11.8 on my sled.
Thank you Skydog
12.5-13.1
Thank you Skydog
powderlites
- Sep 5, 2005
powderlites
- Sep 5, 2005
- 6K
