top rear wheel removal mono shock susp.
GIDDY-UP
NE. PA
06 RTX MONO SUSP.? the top wheels on susp. on rear of mono susp. how are wheels on susp. are they a press on , press off deal? i dont see a snap ring or anything. I want powder coat susp. and need to remove. THANKS in advance.
You need to pound the shaft thru.... I am pretty sure they have a slight press.
There is a snap ring for the bearing i think. take the wheel off and then press off the bearing. That how my 06 gt was
This is correct. They are a very slight interference fit. But corrosion, etc, makes them hard to remove. But, If you take the wheels off, then you can put some pressure on the bearings. You can also use a puller. Make sure you get a the bolt back into the shaft before pulling. The threads inside the shaft are soft.
