Bamboo
Does any one know what the three wires are ground/running/brake?? Putting on a new led break light on the XTX and need some help wiring it up.
cheers
cheers
Not sure but I would be willing to bet that a good multimeter would - have ya checked the readings as of yet?
dansranger
The L/R wire is the fused power. The B wire is the ground. The G wire is the switch power.
rx1 fern
what did you do with your stock taillight .do you want to sell it.
Bamboo
Sorry no oem tail lights left. Also sled is apart so no chance of getting it running to see what's what with a multimeter.
Any one know what each of the three are? Not sure what you mean by the "G" wire etc. is that green or a code from a wiring schematic??
dansranger
Thats the color of the wires
stopdropanroll
rx1 fern said:what did you do with your stock taillight .do you want to sell it.
I have the stock tail light I would be willing to sell. PM me.
Bamboo
dansranger said:Thats the color of the wires
Black , Green and a Blue with red stripe
Bamboo
Figured it out.
Black wire is the ground.
Green wire is the break light(bright)
Blue w/red stripe is the constant power(running light)
G-ball
I have a stock light if you are still looking for one.
SledFreak
- Feb 7, 2005
- Ontario. Canada
Bamboo said:Figured it out.
So, are you just extending the wires to make this work or are they long enough?
Bamboo
The wires that came with the new light were long enough to reach the factory harness.
Yamaporn
- Feb 11, 2009
- Sidewinder L-TX LE
where did you run the wires? Under the tunnel? if so, how did you secure them and protect them from ice buildup?
Bamboo
Yamaporn said:where did you run the wires? Under the tunnel? if so, how did you secure them and protect them from ice buildup?
Pm sent
