NEW Products!!!!! Radiator delete kit...
heath@mpi
That sure is sweet!
It really is too bad that you didn't get this out a couple of months ago, or hinted at it. I probably would have bought one.
Also, this would most likely cut down on a lot of ice buildup in the tunnel.
Have you tried it on the snow yet? Just curious on how it would effect the consistency of the EFI system. I believe one of the reasons for the radiator was to provide a consistent engine temp
Grimm said:
That sure is sweet!
Doesn't look like it would fit a short track.
No it doesn't look like it fits the short track from the pictures and the website. But i would definitely buy one if it did.
It has been tested on the snow and running very consestent temps when riding.
I'm assuming the cooling fan gets deleted as well. If so what are you doing about the electrical connector for the fan? If its not connected to a fan does it generate a code?
