sx7001
- Jun 28, 2003
- Sidewinder
Like we all know setup is the key with the Apex. These shocks give all the adjustment you need to dial in your front end. If you have the GYTR shock keep the rebound close to 10 clicks out and the spring tension on the soft side. On smooth trails set the compression at 6 clicks out and as the trails get beat up go in 1 click at a time.
http://www.youtube.com/watch?v=ZPKrqxQTWlU
