ADDING TO THE FLEET????
jdp1under
CT, NO SNOWVILLE
2010 RS VECTOR GT LTX STOCK FOR NOW!
HELLO GUYS I HAVE A 03 RX1 AND MY BROTHER IN LAW IS RUNNING AN 02 VIPER HES LOOKING TO GET A FOUR STROKER A LITTLE NEWER MAYBE 06 AND UP...... HE DOESNT REALLY LIKE THE RX AS MUCH AS THE VIPER BECAUSE OF THE WEIGHT AND POWER... MY QUESTION IS WHAT FOUR STROKE MAY BE A BETTER FIT???
THANKS
depends on what he likes for seating position. if he likes the viper position, he will want a vector, venture, rs nitro, or an apex as they are closest to that seating position. up graded to a 13mm swaybar, they corner almost as flat as a viper with a good carbide/ski combo.
i was dead set on a 4 stroke untill i rode an 03 with upgraded swaybar and fell in love with the 4stroke torque and pull in the winter of 05/06. found a noncurrent 05 war se and have been happy with it since. i swap out with my brother on his 02 viper or my dad on the 05 sx venture and it pretty much handles the same with the 13mm swaybar.
THANKS GUYS I HAVE AN APEX SEAT AND BAR RISER FOR MY ONLY UPGRADES... I WILL BE ADDING THE 13MM SWAY BAR BEFORE THE SEASON.. I ALSO HAVE SIMMIONS FLEXI SKIS ON THE MACHINE WHAT DO YOU RECCOMEND FOR THE CARBIDES....
AS FOR MY BROTHER IN LAW I JUST THINK HE WANTS A LIGHTER SELD OVER ALL BUT I DONT KNOW WHICH WAY TO GO/....... IS THE NYTRO LIGHTER AND MORE MANOVERABLE...
THANKS JDP
OH YEA I HAVE A STOCK TRACK ON THERE NOW WHAT CAN I UPGRADE TO FOR MORE BIT AND TRACTION BUT NO STUDS..... THANKS
jdp1under - would you please turn CAPS LOCK off.
Typing with caps lock ON is considered shouting on the Internet :-) and it's harder to read in upper case than in lower case.
BTW listen to maim
rxrider
TY Management Team
