beeze455
- Nov 23, 2010
- Bowdoinham, ME
- www.gopherdesign.com
Bunch of threads about pilot ski install, but nothing all that detailed. I decided to detail my install and how I did things and why.
Why pilots? Why 6.9s?
Just about everybody on this forum loves the pilots and many loved the 6.9s. I have an XTX and knew i needed a ski to prevent pushing and to float better. On my cats I always ran C&A, but many said it was just too agressive. Many others like other aftermarket ones, but the pilots still got rave reviews. Then you price them out and they right around 200 bucks and any doo dealer can get them in a few days.
Now the skis themselves are a little to narrow for the yamaha. You can either machine down the bushing or just pull one out and have the washer part be on the outside of the ski. I have read that one person did get it to fit with them both on the inside--goodluck with that.
Pry it out with a screw driver.
Push it in on the side. I put the one that would be on outside on the inside of the ski. This way you would not see the washer part when standing beside it.
They will look like this.
So the next problem is the stock yammy rubber does not fit the ski. You can buy a Ski-Doo ZX rubber--MXZ Chassis from pre-2002 and many others. You can cut the front platic lip out. You can mod the stock rubber boot.
I chose not to cut the ski because it required cutting the ski and I do not have a dremel. I did not do the zx rubbers because I did not have them and did not see the point.
So we know we have a plastic ridge in the way about 3 1/4 up on the boot. Measure up and put a slice almost 3/4" deep.
Sliced, but hard to see.
Boot spread so you can see the slice. The ridge will fit right in.
We have another small ridge in the back, so measure about 1 /14 and take the sides off.
Bushings and Boots changed to fit a yammy.
Next problem, ski loops. The stock ones fit, but require some cutting.
too wide
the opening in the pilots is very narrow compared to stock yammy skis.
Cut the black spots and also shave the sides of the other end to make it easier.
Modded loop end
Install the front first, and dont forget your washers and what way your bolts face. After the front is in, muscle the back in. A screw driver to line up the hole and a quick tap of a hammer can save time.
all done
I bought 7.5 shaper bars, but many buy 6" and put the stock carbides on the outside. I may later.
too wide
Modded loop end
all done
sethryder
- Feb 19, 2014
- Derry NH
- 07 phazer fx
Anyone know why the pictures are no longer showing up?
radianguy
- Jan 1, 2007
Old thread??
Anyway don't waste your time with the 6.9 pilots, just my opinion, but they aren't a great trail ski. I tried them, great floatation but on trail I found they drifted through the turns. Sold them and now have the yamaha mtx ski, just as good flotation off trail but much better on trail than the 6.9's.
beeze455
- Nov 23, 2010
- Bowdoinham, ME
I'll get them backup. Loved the 6.9 on trail and off trail.
sethryder
- Feb 19, 2014
- Derry NH
- 07 phazer fx
Good to hear thank you. I have a pair on the way for the phazer, and would like to modify the rubbers as you did.
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
Here are some picture of when I did mine: http://s589.photobucket.com/user/grizztracks/library/FX Nytro Pilot Skis?sort=3&page=1
And a post when I installed them: http://www.ty4stroke.com/threads/pilot-ski-install-on-nytro.84889/
I've tried several dual keel skis and found them to be inconsistent in their handling on the trails. Their not bad on hard pack but push terribly in loose conditions. I've gone to Curve skis and haven't looked back.
turkster
- Feb 1, 2008
- opaskwayak manitoba
- 2014 nytro xtx
put the 6.9 0n my 08 vector ltx. floated great but still darted hard on the trails(didnt have time to do the shim thing). have stock on my nytro work great for me . have been learning off here that if ya set up suspension for your weight and how ya ride dont have to blow a bunch of money on skis and runners.
turkster
- Feb 1, 2008
- 2014 nytro xtx
dont know about the deep no snow up here this year, but great on the trail.....boringput the 6.9 0n my 08 vector ltx. floated great but still darted hard on the trails(didnt have time to do the shim thing). have stock on my nytro work great for me . have been learning off here that if ya set up suspension for your weight and how ya ride dont have to blow a bunch of money on skis and runners.
