Hello,
I have a 2006 Apex GT and am looking for a replacement rear shock. Mine has the Ohlins with electronic remote adjust. My shock seems to have lost any rebound damping, has visible signs of leaking and needs to be rebuilt. My concept is to remove the Ohlins for rebuild and install a used replacement for the remainder of the (short) riding season here in MA.
Is there a list of replacement shocks that will bolt on without modifications? I found a few used shocks on eBay but compatibility with the Apex GT is not clear.
For example, a rear shock from a 2010 vector LTX GT RER elec start has PN: 8HD-47480-01-00 (Partzilla), but an eBay listed PN: 8GM-47480-01-00. From Partzilla, my shock’s PN is 8GD-47480-00-00, which is close but different in at least the second two of the first three characters. The eye-to-eye length in this listing and my measurement are the same.
(edit: Hygear offers the 70108-RA for $1,079, but I was looking for a lower priced used shock.)
Thank you for any help,
Ben
Ben
Elton Buss
You can us any shock from a mono skid. 121and 136 length is the same
Elton Buss
You can check with Travis at barnofparts he had one listed with hygear spring
Thank you
chris189
- Nov 27, 2011
- Hanover Ontario
- 2007 Apex GT, 1980 Enticer 340
Not sure if you use the electronic adjust much but I have been told the kyb(standard shocks) were actually more durable. You just lose adjustability with them (no compression adjustment). With a revalve they ride pretty good. Remember to set your sag.
DGZRT
- Feb 23, 2006
- Stevens Point Wisconsin
I have a standard mono shock from a 2009 Vector if interested. Let me know I’ll shoot you a price.Hello,
Ben
