yamiracer500
- May 13, 2008
Replaced stator and tested coil, checked key, kill switch battery and pretty much everything else. Reverse light stays on even when neutral light is on, don't know if relays make it not have spark or if cdi unit could anyone with any testing info or any suggestions would be much appreciated. I have been working on it for two days strait for like 10 hours each day and cannot figure it out. Thanx
Could be a relay for the shift indicator?? Check to make sure that the left side brake lever switch is not stuck or the foot brake lever switch is not stuck...
