superfan75
- Sep 12, 2013
- West Topsham Vermont
- RX Warrior
BigDog how has that worked out for you ? I made a bracket and set mine up the same way you did. I haven't had enough snow to ride yet so I haven't had a chance to try it out either.
Jim yamawheels
- Jan 26, 2016
- Mequon
- RX-1 mountain
Thanks for the picture. I will put a set on mine.Mounted mine inside of frt skisView attachment 115232
BigDogrx1
- Dec 2, 2014
- SOO (UP) MI
- 2003 rx1
Superfan they work real good. Nice and easy to drop down when wanted.BigDog how has that worked out for you ? I made a bracket and set mine up the same way you did. I haven't had enough snow to ride yet so I haven't had a chance to try it out either.
superfan75
- Sep 12, 2013
- RX Warrior
Good to know. Thanx. Hopefully I'll get to try them this winter.Superfan they work real good. Nice and easy to drop down when wanted.
Theblackbullet
- Jan 12, 2010
- NW Ohio
- 2004 RX Warrior
Just do the Apex radiator install it is easy except bleeding the lines and you can find them everywhere cheap. I also used to install temp gauges in all of my sleds.
Do you know if the RX has a water sending unit already in line that you can just plug a gauge in and go? Or do you need to add a sending unit to add a guage?
smokingcrater
It is easy to add one, that is a better option vs screwing around with any factory temp and possibly disabling the safety features at the same time. Just splice in a hose adapter on the piece that comes off the top of the engine. I added a radiator to both of my sleds in the my .sig, can't be happier. Easy, relatively cheap (if you find one used at least), and effective.
Theblackbullet
- Jan 12, 2010
- NW Ohio
- 2004 RX Warrior
I was leaning towards adding one, I think autozone has them for $15 or so, and gauges for not much more. Pretty cheap compared to a melted down engine.
Jim yamawheels
- Jan 26, 2016
- Mequon
- RX-1 mountain
I will be purchasing ice scrapers for my 03 rx-1 mountain, an 04 warrior and an 06 nitro from straight line performance. Can someone tell me what length to get 12" or 16"? Where would the best place to mount them the slide rail or arm?
BigDogrx1
- Dec 2, 2014
- SOO (UP) MI
- 2003 rx1
I like them mounted on frt skis on inside, dont remember what size, but would guess the longer ones.I will be purchasing ice scrapers for my 03 rx-1 mountain, an 04 warrior and an 06 nitro from straight line performance. Can someone tell me what length to get 12" or 16"? Where would the best place to mount them the slide rail or arm?
Easy to make a small bracket for them to mount to.
Jim yamawheels
- Jan 26, 2016
- Mequon
- RX-1 mountain
Can anyone tell me the length of the front shocks of an 04 rx warrior from center bolt to center bolt. Looking to get new shocks.
Jim yamawheels
- Jan 26, 2016
- Mequon
- RX-1 mountain
I am putting ice scratchers on my 03 RX-1 mountain to reduce overheat sensor light from coming on. Where is the best place to mount them on the skies or the sliderail? I put in a rear cooler in place of the crossover tub.
DJsTuffMods
- Nov 17, 2014
- Chicago, IL
- 2003 Yamaha RX-1
My buddy owns a 13 Apex and we were both out on some hard packed trails. While cruising nicely threw town we were constantly getting the flashing lights. A few times the Apex shut down.. We then solved that problem by several quick WOT for split second intervals and it definitely got rid of the flashing light! We continued that throughout the rest of our trip
! I found it odd that my 03 didn't overheat half as much as my buddies NEW Apex..(ONLY 300miles on it)..? I'm pretty sure his sled had a cooling fan in the front and another heat exchange in the rear but maybe i'm wrong..
! I found it odd that my 03 didn't overheat half as much as my buddies NEW Apex..(ONLY 300miles on it)..? I'm pretty sure his sled had a cooling fan in the front and another heat exchange in the rear but maybe i'm wrong..Similar threads
