chip 156
- Jan 19, 2018
- Mason, Wisconsin
- 2003 rx1, 2006 vector mountain 2005 venture
03 Rx1 ...7200 miles the oil tank drains into the crankcase when in storage..have heard it may be the 'seals' in the oil pump that allows the oil to seep in over time....is it time to change the oil pump?? thanks..first time posting hope we did it right..
chip 156
- Jan 19, 2018
- Mason, Wisconsin
Hope someone can let us know if or what is the issue on this..why the oil seeps into the crankcase,,and to replace oil pump..can you do that without removal of the motor..can the leak into the crankcase be caused by a faulty oil cooler? .thanks again and if any one has any ideas???
Al Bundy
Here's a start...Hope someone can let us know if or what is the issue on this..why the oil seeps into the crankcase,,and to replace oil pump..can you do that without removal of the motor..can the leak into the crankcase be caused by a faulty oil cooler? .thanks again and if any one has any ideas???
https://ty4stroke.com/threads/oil-tank-reservoir-empty.132674
chip 156
- Jan 19, 2018
- Mason, Wisconsin
Thanks Al, its closer but ..where is this Check valve? in the pump. or line.. and what needs to be done??
Al Bundy
I'm not sure...Anyone have information to help out this fella?Thanks Al, its closer but ..where is this Check valve? in the pump. or line.. and what needs to be done??
Al Bundy
Did you start the engine?03 Rx1 ...7200 miles the oil tank drains into the crankcase when in storage..have heard it may be the 'seals' in the oil pump that allows the oil to seep in over time....is it time to change the oil pump?? thanks..first time posting hope we did it right..
chip 156
- Jan 19, 2018
- Mason, Wisconsin
yes.. the tank refills and the motor runs Great...but would like to fix what is wrong,,Anyone??
Al Bundy
All I can tell you from personal experience is a few times when my sled has sat for a week I checked oil level in the tank and it was low. So I'd start the engine and let it idle for a few minutes. I would wait about 5 or 10 minutes after killing the engine to re-check the oil level in the tank and it would be fine.yes.. the tank refills and the motor runs Great...but would like to fix what is wrong,,Anyone??
I assume oil had drained back to the engine similar to your situation, just not as drastic.
chip 156
- Jan 19, 2018
- Mason, Wisconsin
Thanks..it does drain slow..usually 30 days to almost empty..thanks again
That's normal. That's why when changing the oil one must drain the crankcase too.... Separate drain plug behind a plate....
- 32K
