Lagman
- Feb 4, 2013
Well I unloaded today, and if course a problem. Cold start no flashing for warm up, let it idle for 5 and run it for 5. Warning light cimes in, stays on. Shut down. Restart after 5 min looks good. Take it for a ride all good at 1/2 throttle and above. 1/4 runs ruff like a miss. Change plugs, nada. Take a 2 hour rude runs great except low throttle. One thing I notice, coolant level ain't moving. Moves a little when I pinch the hose but I don't know, them hoses were hot as hell.(thermostat?) What am I missing. Fresh premium gas today. Help want to rude I. The am. WNY has good snow!
most rx sleds do not like 91 octane. they prefer 87 when in use during the season. only fill with 91 at the end of the season if you do not drain and run your sled out of gas. try a shot of seafoam or mechanic in a bottle if you can get it.
Indy
x2 on the premium, it will not help at all. You need to do a carb cleaning before anything else. You may need to do it twice. Pump out the fuel to almost empty, Put in a bottle of Mechanic in a Bottle, start and let run for 1o/15 minutes. Let it sit for an hour, then clean your jets.
this will more than likely fix your problem.
Lagman
- Feb 4, 2013
Can a foul carb kill a cylinder and hurt the engine if you run it?
Indy
yes and yes.
smokingcrater
Lagman said:Can a foul carb kill a cylinder and hurt the engine if you run it?
Can running a jet half as big as it should be be bad... yep!
