ualav8
Just put a new Yamaha belt on it. Wife has been riding it for a while. In the meantime, I've been riding------the 2 up. Sigh.
Anyway, I'm getting back on the rx. It has about 7500 miles on the original clutches. Time for a clutch rebuild? Engine seems strong otherwise. New plugs and carb cleaning this season. 87 octane no ethanol. Rpm max's out around 9300 rpm and gets up around 100 mph. Suggestions??
I would suggest a clutch disassembly and cleaning as there is probably belt dust and corrosion.
RxThunder
I just had this same issue with my RX1, I took my clutch off, took the cover off, spring, rollers and weights out, I hand scrubbed the entire clutch with dish soap. Mine was covered in a thick coating of grime. I used an entire can of break clean, and then ran it through the dishwasher with no soap and stopped it before the dry cycle. I gained about 800 RPM which put at 9,800. Still could hardly break 100mph on the speedo. I cleaned and synced my carbs, I am now at around 10,100rpm and was able to hit 122 on the speedo this weekend. The sled runs much smoother and noticed a decrease in fuel consumption.
YammieMan
After washing it, do you lube it all? Or is it best just to leave it. Thanks.I just had this same issue with my RX1, I took my clutch off, took the cover off, spring, rollers and weights out, I hand scrubbed the entire clutch with dish soap. Mine was covered in a thick coating of grime. I used an entire can of break clean, and then ran it through the dishwasher with no soap and stopped it before the dry cycle. I gained about 800 RPM which put at 9,800. Still could hardly break 100mph on the speedo. I cleaned and synced my carbs, I am now at around 10,100rpm and was able to hit 122 on the speedo this weekend. The sled runs much smoother and noticed a decrease in fuel consumption.
Brotherdan
- Sep 8, 2017
- Belmont,maine
- 2011 apex xtx blue, starr suspension,gytr front shocks,camso 1.5 track cut down, snowtrackers work in process,2003 rx1er originally 121 converted to 136"monoshock 2 ck136 rear suspension with clicker vector ltx shock,muffin works tunnel extension, seat concepts(wrp) seat,apex hooked handlebars converted to all underhood wiring,8"lake effect billet aluminum riser,gytr frontshocks,yamaheater hand warmer kit,rocks ridelite,rocks power supply, rocks heated bag,, tunnel braces,blue skid plate,garmin gps, aggressive snowtrackers on apex single keel skis,rollerski ski wheel kit,108 warthog studs&blue studboy backers,pioneer wheel lowering kit, dupont slides, 4th wheel kit,yamaha saddle, tank& windshield bags, powermadd led handguards, bar mount mirror kit, apex radiator& electric fan added, apex rear cooler,autometer temp guage, apex new style large diameter drive shaft with extroverts machined for chaincase,thunder products clutching,1987 enticer 340ltr 2100miles,1984 enticer 340,1996 wolverine 350,big wheel kit,winch,racks,k&n,full skidplates
Just dry,any type of lube with cause belt slip&attract belt dust,dirt etc,some guys put wd40 just on the faces to stop corrosion ( with belt off for storage only!!)it must be cleaned of the faces before installing belt&running againAfter washing it, do you lube it all? Or is it best just to leave it. Thanks.
YammieMan
Thanks!!!Just dry,any type of lube with cause belt slip&attract belt dust,dirt etc,some guys put wd40 just on the faces to stop corrosion ( with belt off for storage only!!)it must be cleaned of the faces before installing belt&running again
