brad barbour
- Dec 8, 2018
- NWT
- 2004 RX1 Warrior
Hey Folks,
I had a ac adaptor port installed in my sled so I could plug in my heated visor while up north. Last winter I plugged in my Sat phone to charge it while the sled was running and it shut off. When I turned the key it didn't have a gig so I figure I blew the fuse. Does anyone know where I can locate it to change it. unfortunately I live in the Arctic where everyone has 2 strokes sleds so no one locally knows anything about it.
Brad
Brad
It should be under air box next to the battery. It is mounted on the battery box bracket.
RobX-1
- Coldwater, OH
Whenever in doubt, always check the micro-fiche. Here's a link to Port Yamaha's:
https://shop.portyamaha.com/fiche_select.asp
Or better yet, become a VIP member on this forum which will allow you to obtain the service manual for you RX Warrior.
mover92
- Jan 21, 2024
- Wisconsin
- Apex
Actually, your diagram is showing the starter solenoid relay. The ignition fuse is a 40A green cartridge fuse located forward a bit of the starter relay and lower. My 06 attak went dead when I hooked up the battery backwards. ^&&**((()( haha I couldn't find a fuse, and couldn't find info on it online. I was looking for bad grounds, but they looked ok. Frustrating. after 6 hours of my trying to figure it out, My wife found it by digging around and tracing wires. Oreillys had on in stock, I bought t 2 for 10 bucks. Back on the trail again!
