cole397
- Dec 27, 2014
- 07 apex carb
I have 2 sleds, both same things, pulled carbs off them and cleaned them put them back on, even synced them,and they fire up great.. idle awesome, but when u hit throttle it hesitation to get to full rpm.. kinda surges from half throttle to full throttle.. what am I missing.. carbs are clean for sure..
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
What are your fuel screws set to? They might be too rich.
cole397
- Dec 27, 2014
- 07 apex carb
think its stock... 2 turns from seated?
cole397
- Dec 27, 2014
- 07 apex carb
and I synced them all. there perfect
cole397
- Dec 27, 2014
- 07 apex carb
minus running good lol
tproteau
- Sep 28, 2014
- Wpg Manitoba
- 2003 Yamaha Rx-1 LE Liquid Silver
1998 Polaris XC 700
2007 Ski-Doo MXZ Adrenaline 800 HO
did you put any rubber parts into contact with carb cleaner?
Dalooch
- Feb 14, 2015
- Rx1
This one time I cleaned the carbs and thought they were clean......till I did them again. My buddy swears he did his right also swears by it. On further inspection they were clean but upon putting his jets in he mixed them up. A small piece of debris in them jets will play havoc. What throwing me is you say it's hitting full RPM?
smokingcrater
Did you fishline out your jets? Also, check your vacuum lines for cracks, and last, check the covers on the unused vacuum ports on the carbs. If those crack you end up with a vacuum leak.
YammyRX1
- Jan 26, 2009
- Milton, on
- 2003 Yamaha RX-1
Both started running poorly at the same time? I would drain fuel and replace with fresh.
