rroslintfd
- Jan 16, 2021
- Yamaha RS Vector 03 and 05
Yamaha Snowmobiles
Hand and thumb warmers not working and not displaying on the screen, they are the adjustable type, the code light is blinking 2 slow blinks, I have ohm'ed out the warmers and they are fine, someone said it might be the ECM, changed that out from a working one, no difference, I'm lost from here.
Yamaha Snowmobiles
Sounds like there could be a short. Have you check continuity on each grip and thumb warmer?
fuse?
rroslintfd
- Jan 16, 2021
I checked the main fuse bank, is there another place to look?
there is a fuse box above the chain case with mini fuses in it. the only other place i am aware of is the 2 on the solenoid down by the battery box.
Winter
rroslintfd
- Jan 16, 2021
if you could email it me at rroslintfd@aol.com
