Xtreme51
- Mar 16, 2008
Just picked up a new clutch for the sled(100% stock), FS weights with no rivets and a green-white-green spring. Can I use these weights at 500' -1000' if I ad rivets and change the spring?...or if not, what would be the best weight and spring to use(I want to run stock parts)? All groomed trail and lake running.
Bigblue1
You could but I don't see why. A very good reliable kit is the bender kit which I believe uses heavy hitters. I put 18000 very fast and hard driven miles in your exact conditions with not one issue. When I first put it on the change was night and day with low engagement but very smooth but hard pull. Well worth it.
- Apr 14, 2003
- Hessel, Michigan
I'm all or the Heavy Hitters also...they work great in RX-1's
tedgoesfast
The only way stock weights will work really good if you have a team tied secondary other then that get a set of after market like they are saying mine worked best with a set of Dalton weights and a 40 128 front spring
we like the drag'n'flys on my brothers rx and my apex.
