I was replacing the bearing on lower clutch side and I'm sure my new bearing isn't pressed in far enough. When looking underneath I see a gap that wasn't there with the old bearing but I can't get it to seat any farther?? Does this look normal or needs to. On on further?
I always leave the set screws loose. I put on the outside plate tightening the three nuts equally. Then I tighten the set screws. This works unless you have the gears out of the chain case
