wildmann
- Dec 11, 2005
- Southern WI
- 16 viper rtx-dx
11 venture gt
09 vector ltx gt
05 vector
05 Vector seems to run on 2 cylinders at low speed, as you increase throttle it seem the third cylinder kicks in. Where do I start looking, Electrical or carbs or both, cleaned carbs last year, Any help would be appreciated,
theCATman
- Feb 19, 2007
- WI
- Yamaha
My '07 does the same thing, especially after sitting for a long time (days/weeks)
It is better after I synced the carbs, but it still does it a bit.
My sled in particular sounds more as though it's actually loading up and sputtering vs a cylinder not firing.
AftonJay
- Oct 23, 2012
- Northern Michigan
- 2005 Warrior, 2009 Nytro XTX and Arctic cat puma for the kids
- Afton Mi
I would run it in the dark with the hood open see if you see any arcing around the coils. If not clean the carb, check the plugs and if you can figure out which one doesn't seem to be firing switch around the coils to see if it moves with those.
Pilot jet clogged...
As soon as you raise the jet needle, the cylinder kicks in.
2 different jet. Needle jet never plug, Pilot jet very picky.
Overnight it in carb cleaner.
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Don't bother trying to clean it. Just replace it....they're cheap.
ontarioyamaha
- Mar 26, 2017
- Port Perry, Ontario
- 2010 Vector ltx GT
2010 MXZ X 1200
- Port Perry
Yes, I agree, pilot circuit plugged. Pull and clean with a small piece of electrical wire. Cut open a 12 volt stranded wire and use 1 piece. Remove the jet. Insert the wire through the jet and spin it. I normally clean carbs yearly as a preventative measure.
Also, blow the carb pathways out with air.
