after rebuilding the carbs last year, I decided to synch the carbs with the carbtune I recently purchased. So i go out to start sled and had a hanging idle at 2500 rpms and when it did drop a minute or 2 later it stumbled at 1000 rpms. If choke was applied just a frizzle the rpms would climb again but even out. Long story short one of the fuel pickups no longer has the filter attached. So now the filter that remains is coming off and there will be 2 new inline filters next to my fuel shutoffs. So check your filters fellas, cheers
bigal1951
- Oct 17, 2008
- St. Andrews, MB
- 2014 SR Viper XTX
2004 RX Warrior
My Warrior starts and idles OK; but, when I try to accelerate it misses and will not pickup. Are the fuel filters my problem and how do I get them out?after rebuilding the carbs last year, I decided to synch the carbs with the carbtune I recently purchased. So i go out to start sled and had a hanging idle at 2500 rpms and when it did drop a minute or 2 later it stumbled at 1000 rpms. If choke was applied just a frizzle the rpms would climb again but even out. Long story short one of the fuel pickups no longer has the filter attached. So now the filter that remains is coming off and there will be 2 new inline filters next to my fuel shutoffs. So check your filters fellas, cheers
Indy
theyre in the tank. either have a very young one with small hands grab them or use a coat hanger to fish them out.
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
