mapo
- Sep 12, 2021
- Apex Gt
Alright, so just got around to finish things up on this sled, put the temp gauge on and bled the system, just changing the wheels now. Changed the rear 3 and top two 7 inch bogey's, The way I did it was just loosening the track and taking out the 2 rear skid bolts going into the bogey shaft. Now im stuck on reinstalling the skid up. I Put the bolts on, but they aren't getting tight, they just spin and seem like they grab but then let go, could they be striped? or is there a trick to it? One of the bolts is clearly different than original, they must've put another one in before. Any ideas??
some times you need to hold the bolt on the other side when you tighten them up as the shaft spins when you try to tighten or loosen the bolts to pull the suspension.
