ltemple
I have an 06 Attak and an thinking of changing the gearing, currently 23/38. I know off line and top end will ultimately change because of the new ratio. I trail ride very aggressively and play on the lake with the radar gun a few times a year. What my question is (because I dumb and don’t know), If I where to line up too identical sleds one with the 22/38 at 1.73 ratio and the other with 23/40 at 1.74 ratio, is there a noticeable difference ?
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
The top end but not a lot.
arteeex
All other things being equal in the drive system, you could expect to see a gain in top-end speed of 0.57471%. Rounding off, this means to realize an additional 1 mph with the change you will have to be going 175.2 mph.
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
23/40 is slightly more efficient as the sprockets are larger.
It should be the best.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
arteeex said:Rounding off, this means to realize an additional 1 mph with the change you will have to be going 175.2 mph.
Know we just need to fine a yamaha that gose that fast. :rules
ltemple
Thanks guys, I thought I read somewhere that the larger bottom gear was a little more efficient but I am here to learn.
- 6K
