06 Attak rear Ohlins install.....
viperlover
Sycamore, IL
I'm putting an Ohlins electronic rear shock and pigtail on my 06 Attak. Just looking for a lil info on where the plug is located on the harness to plug it in before I go dismanteling all the plastic to find it. Any help is appreciated. Thank you!
Viperlover
The connector is located just above the extra radiator under the right (brake) side. You thread it up from the tunnel thru a hole near the chaincase. There is a cable holder about half way up to keep it from getting into the chaincase. The connector for the shock is taped in with some other wires. :rocks: Hope this helps! Regards, Chuck
